good clutch for the daily
Old Jul 17, 2012 | 07:10 PM
Sik Eg's Avatar
Default good clutch for the daily
Hey HT I need some help I will have to replace my clutch soon and I wanna know what's a good one to go with I figured a stage 2 is good for me but not sure what company go with LMK guys thank you
Old Jul 17, 2012 | 07:13 PM
grumblemarc's Avatar
The Grumpiest
Default Re: good clutch for the daily
Let's clarify this. "Stage Whatever" means nothing. It is not a standard. No two companies "stages" mean the same thing.
Clutches are not rocket science either.
Get a clutch that will hold the torque you are making or plan to make.
I'm guessing since you didn't mention car or mods that you are N/A so an OEM replacement will suffice. Exedy is what I would buy.
Old Jul 17, 2012 | 07:14 PM
MEn'MYEK's Avatar
Are you making high HP and torque #s? If not stick with an Exedy OE spec clutch and pressure plate. No need to put a stage 3 clutch or something like that on a car making like 160hp. Use the $$ you save with the OE clutch and get a light weight flywheel
Old Jul 17, 2012 | 07:19 PM
Sik Eg's Avatar
Thanks guys
Old Jul 17, 2012 | 07:23 PM
mike:'s Avatar
If you're just buying a clutch and not a pp/fly/clutch kit remember to get a clutch alignment tool, should be less than $5 and a major PITA if you try without it or get to that stage of the swap and realize you need to order one
Old Jul 17, 2012 | 07:55 PM
Sik Eg's Avatar
Yeah I'm going to order a clutch kit so it should come with everything
Old Jul 17, 2012 | 10:51 PM
jbpnoman's Avatar
We know nothing about your car, how much power you're making, or what kind of driving you do.
Get a sintered iron clutchpack. You'll thank me later.
Old Jul 18, 2012 | 05:56 AM
Sik Eg's Avatar
All stock SIR that's what I have but I plan on building a head over the winter too
Old Jul 18, 2012 | 05:59 AM
The Grumpiest
That head will not net you enough power to overcome an OEM replacement clutch.
Old Jul 18, 2012 | 07:51 AM
Sik Eg's Avatar
Ok so a oem clutch kit I should get is what your saying .? Not even a stage 1
Old Jul 18, 2012 | 08:35 AM
The Grumpiest
Stage 1. What does that mean exactly?
Old Jul 18, 2012 | 09:10 AM
Sik Eg's Avatar
Dude idk that's why I'm asking you guys for input I'm not exactly sure what the diff stages mean I know as you go up they are more aggressive
Old Jul 18, 2012 | 09:13 AM
The Grumpiest
You must have missed this.
How are you even talking "stages" when you don't even know what that means?
Again. The only clutch you'll need is the one that holds the torque.
Old Jul 18, 2012 | 10:07 AM
Jimster480's Avatar
You cant just ask, what clutch is good without giving us some information on the setup. if you are asking about OEM replacement then say so.
Old Jul 18, 2012 | 11:35 AM
Sik Eg's Avatar
Lmao ok guys thanks I get it ok I'm gonna go oem thats good enough thanks for the help
Freemananana
Transmission & Drivetrain
Jul 7, 2014 08:33 AM
s2k_8582
Honda S2000
Jul 20, 2011 12:09 AM
vg7z
Sep 5, 2006 06:58 PM
carlos11
Nov 7, 2005 06:27 AM
CivilizedCiv
Jan 25, 2002 07:17 AM
