93 Honda Civic Si losing power?
Heyy guys about 3 days ago I was driving my 93 civic si when it started to just sputter and it seemed to lose power. When this happens if I give it more gas it seems like the car pretty much start to slow and the RPMs drop until I either shift or just let up off the gas. I have no idea with this could be the CEL is not on and I havent really done anything to it for awhile. It has the D16Z6 motor. Any help would be great guys thanks,
Cody
Cody
Re: 93 Honda Civic Si losing power?
Alright so far I have changed the plugs but it still did it. But now I am thinking its in the fuel system I just changed the fuel filter but wont know if it fixed the problem until I drive it so I will let you guys know but as for the old filter it had alot of crap in it so I am hoping thats what it was. But like I said I will let you guys know and go from there.
The fuel cleaner may have broke loose some sediment in the tank that may have clogged the fuel pump sediment screen as well as the fuel filter. I think the fuel pump is located inside your gas tank and the sediment screen hangs off the pump. It's not that hard to change. On my 93 del sol the fuel pump access is on top of the gas tank.
as wierd as it sounds. I think it is the coolant temperature sensor. Had this problem with one of my civics. It would bog out at about 2k rpms. replace the coolant temp sensor ( not the sensor for the gauge but the larger one near upper radiator house. Otherwise it could be 02 or cracked manifold near the 02? Let us know what you find out.
Alright well my guess is that it was the fuel filter because since I have changed it its been running good as new! Its about time its a cheap easy fix lol but thanks for all the info guys!
Glad you got it fixed. Yea its strange a coolant temperature sensor is the last thing i would think of if my car is bogging. Fuel filter was a nice cheap fix, how relieving.
Well I guess I lied it only seem to have fixed it for about 2 days and then it started doing it again. O.o Sorry guys I thought it was fixed but tonight I did go ahead and change the coolent sensor, I have a few extra ones. lol But if this doesn't fix it I will let you guys know what I will try next until I get this fixed lol But again sorry for telling you it was fixed I really thought it was lol but we will see how far this coolent sensor will get me. Thanks again!
Alright guys its been like a week since I have worked on the Civic and I chaged the coolent temp. sensor, the one with the little pong like plug and it has been running just fine. So the answer to the problem here would be the "Coolent temp sensor was bad" which makes no since to me but it seems to be fixed so...
92cb7sk8er
15
01-24-2014 06:12 AM
cennouu
11-19-2010 07:43 PM
pinoyboy204
03-07-2007 06:32 AM
