What are your Koni Yellows set at? *Daily Drivers*
So i hear a billion ground control spring rate threads but not many on what your koni yellows are adjusted to. I'm running 450lbs front/380lbs rear gc springs. Right now my koni's are about one half turn from full soft. Should these be dampened more? I'm a one finger gap in the front. What are your rates and what are your koni yellows adjusted to?
i have the same gap/ spring rates as you, and im one full turn from soft in the front and 1.5 in the back. rides perfect, kinda stiff but perfect for me
I just called GC and gave them the numbers on the springs. Found out i've got 340 lb. springs in the front and 350 lb. springs in the rear lol. Guess i'm gonna have to make some changes.
The setting should be set at whatever your normal or average speeds are. There should not be any bouncing just a firm feel when you encounter a bump. That's how you know the rebound is in perfect tune with the spring rates. I forget the amount of turns but I might be 1 full turn from full stiff in the rear and 3/4 from full stiff in the front on 450/400.
It's really going to vary depending on your spring rates. The same setting on different springs will feel totally different on the road.
Depends on spring rates and personal preference of over/understeer.
Koni/GC 550/450, full stiff then backed off ever so slightly. So yes full stiffness. DD'ed like a boss.
this guy make sme laugh
op do what i did. put on full soft drive around. stop. adjust the front and rear a half turn. and so on and so forth until it feels riight, took about an hour to do but never been happier here (450/350)
Where'd you end up? I turned my shocks all the way up because my teggy tripods very badly (rear wheel gets almost 2 feet off the ground when I enter or exit parking lots) and with the shocks turned down, the spring pops out of its perch and it makes a very loud clanking sound when it seats
if you put the front on fullhard the arrow indicater is 180 degrees from still. and the rear is on full stiff, rides great to me. even the wife likes it
