GSR swap HELP!!!!!!
Old Jul 16, 2012 | 09:43 PM
97reddelsol's Avatar
Default GSR swap HELP!!!!!!
Hey guys i have a 97 del sol (OBD2A) and a 95 GSR motor with a 97 trans and a obd2 engine harness.
Im going to run a P28 chipped ecu with a jumper harness and a Skunk2 intake manifold. I was wondering if i need to add a crank position sensor and if there is anything i am forgetting. Also i am going to be extending and bending my oem shift linkage to fit so thats good. Also i have a OBD2 dizzy and the starter is in and battery relocate to the trunk and painted and shaved bay.
heres a pic if there is anything you all can think of id gratefully appreciate it.
Old Jul 16, 2012 | 09:47 PM
Dc4LsTeG's Avatar
EK9
Default Re: GSR swap HELP!!!!!!
You don't need to run the crank position sensor if using a chipped obd1 ecu
Old Jul 16, 2012 | 11:19 PM
Ok awesome that's a relief is there anything else you can think of that I'm over looking?
Old Jul 20, 2012 | 04:40 AM
rice a roni's Avatar
don't use an intera rear t bracket. replace atleast left engine mount with an innovative or hasport unless u want nasty black **** all over.
Posted from Honda-tech.com App for Android
Old Jul 20, 2012 | 04:45 AM
YZFR6's Avatar
You won't need a crank sensor, go and buy an Integra GSR or even better a 93-97 Delsol DOHC one. This will fit your civic shifter no problem.
JDM_cencal
13
Mar 27, 2017 06:29 AM
shaggyeg6si
Feb 1, 2010 09:51 AM
onesiksol
13
Dec 4, 2008 06:04 AM
del_slow
Feb 23, 2005 12:46 PM
yaya
Apr 11, 2004 10:18 AM
