mtf
pennzoil synchromesh works very well too, and even better it's available at any autozone, napa, etc.
but i must stress to you, like spadam said:
DO NOT use synthetic motor oil
DO NOT use gear oil
There is a plug on the passenger side, above the drain plug and toward the rear slightly.
but be aware, if the car is not level (ie, jacked up from the front) the trans will not hold anywhere near what it's capacity should be. otherwise, just fill till it starts to run back out the hole.
10w30 as cheap as you can get it or synthetic if you wanna blow some bills.
A customer of mine claims 6+ seasons on his 92-93 Teg tranny after LSD/FD install using only Mobil 1 10w30.
enoker001
Transmission & Drivetrain
Jun 25, 2009 11:09 PM
ApolloSpeed
38
Mar 13, 2006 11:22 AM
wizzards581
12
Mar 6, 2003 11:15 AM
