Transmission & Drivetrain Gearboxes, Differentials, Clutches
B16 Gearbox sticking in gear! Help =(
Old Jul 12, 2012 | 11:10 AM
lil_foy's Avatar
Default B16 Gearbox sticking in gear! Help =(
Hey guys,
A little while ago my b16a2 (hydro) box started getting stuck in reverse (possible to unselect with some resistance). After researching I found it could be the 5/r synchro sleeve. So I recently got the box rebuilt with a synchrotech 5/r sleeve, synchro and spring. I also installed new oem seals and bearings at the same time too. Now I just got the box in last night and it is still getting stuck in reverse, it's possible to get out but there is definentally some resistance like before.
Does anyone have any ideas what could be causing this? I really don't want to pull the box apart again to replace the wrong thing again :/ labour is expensive in Australia.
Any help would be greatly appreciated!
Thanks guys.
Old Jul 12, 2012 | 11:45 AM
Aquafina's Avatar
Default Re: B16 Gearbox sticking in gear! Help =(
You're going to have to pull it again. I would take it somewhere else to have it rebuilt this time.
Old Jul 12, 2012 | 11:49 AM
lil_foy's Avatar
Any idea on what I should look at replacing now though? Every gear goes in and out perfectly no crunches, it's just reverse gets sticky trying to unselect it.
Old Jul 12, 2012 | 02:07 PM
David @ Synchrotech's Avatar
Check the reverse idler gear for a worn bushing and also look at the main case where the 5/R fork goes in. If the trans housing is dinged at the end it may be causing the fork to get stuck.
Lindsay Horton
Mar 23, 2018 07:51 PM
Shidi
Jul 29, 2017 07:57 PM
worx
May 21, 2010 08:15 AM
vti444
May 7, 2009 09:23 PM
dannie
Jan 30, 2009 01:26 PM
