walbro 255lph = going out only after 1yr?
Old Jul 12, 2012 | 05:31 AM
Charlie Moua's Avatar
Default walbro 255lph = going out only after 1yr?
SETUP:
gsr turbo
350whp e85
fic 1100cc injectors
walbro 255lph fuel pump
*** STOCK FPR & rail ***
-6an inlet line with turbosmart liquid filled fuel PSI gauge
History:
I installed turbo kit & the NEW WALBRO fuel pump 5-2011
Car was tuned and driven for about 500 miles max, then car was in storage for the past 9months.
FUEL Symptoms:
I recently took the car out to tune it with my new FIC injectors (previously pte 780cc).
I noticed that at idel fuel PSI was around 25psi only.
As the tuner did pulls i notice fuel pressure would rise to about 40psi then drop back down near the top (6500rpms or so) to like 20psi fuel pressure.... because of this my powerband is somewhat choppy up top due to fuel pressure not holding steady.
Possible Issues:
1) fualty OEM FPR... doubtful but you never know..
2) bad walbro pump.... sitting in storage full tank of e85 cause it to go bad?
3) other options?
Old Jul 12, 2012 | 05:42 AM
blackeg's Avatar
Default Re: walbro 255lph = going out only after 1yr?
ive had friends with walbros that went bad but those cars were chronically run on 1/8 of a tank or less.
it could have something to do with the e85 but i dont know for sure
Old Jul 12, 2012 | 06:56 AM
TKERacer619's Avatar
Not a Walbro but the last fuel pump in my XJ died after about 10 miles.
I would not be surprised if the pump, regulator, or both is bad.
Old Jul 12, 2012 | 07:04 AM
Turbo-LS's Avatar
Did you have fuel stabilizer in the tank for those 9 months?
Old Jul 12, 2012 | 07:50 AM
while in storage, i never even started it once.
tank was 80% full of e85 , no fuel stablizer used.
before starting the car, i did pump out the old e85 and put new fuel in there.
Ran the car for about 200 miles on new injectors & fresh e85... then finally got a chance to dyno it.
Old Jul 12, 2012 | 08:07 AM
Turbo-LS's Avatar
I dont know a whole lot about ethanol but I'm sure I've read several times it's corrosive and if going to be sitting best to drain tank. Someone correct me here if I'm wrong.
Old Jul 12, 2012 | 08:36 AM
Gunmetal_B20_Hatch's Avatar
Fuel pumps HATE being stored in fuel for extended periods.
Old Jul 12, 2012 | 11:53 AM
since i may end up getting new pump, might as well upgrade...
I want the Deatschwerks DW300 320lph but they only make it for EG/DC
what would it take to get a EG pump to work on EF?
Old Jul 12, 2012 | 12:42 PM
m3tech95's Avatar
buy a new pump.....walbro 255 sitting for 9 months with E85 is a bad combination..upgrade your fuel pressure regulator
Old Jul 12, 2012 | 01:15 PM
Turbo-LS's Avatar
Walbro makes a 450 that is designed to work with E85
Old Jul 12, 2012 | 03:22 PM
direct drop into ef ?
does it need to be rewired to draw more power?
Old Jul 12, 2012 | 03:31 PM
Ideally, ALL sftermarket pumps should be rewired to a relay and direct battery voltage. You'd be surprised at the voltage drop across 20+ year old wiring.
Old Jul 12, 2012 | 03:45 PM
hum... good point...
i guess before buying new pump i should check to make sure there isn't any issue with the stock wiring..... lol
Old Jul 12, 2012 | 08:39 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Regardless, I have personally had 3 Walbro 255 fail while I waited for somebody to release an E85 compatible "in tank" version. The 255 isn't a bad pump, it just isn't designed to be used with E85. I don't have any pictures, but all the pumps looked like clogged arteries /pipes with white corrosion. The new E85 Walbro will fit on an EF hanger with some slight modifications and wiring work around. The problem is the regular pumps aren't sealed enough...
Old Jul 13, 2012 | 06:57 PM
ralph11sec's Avatar
have used walbros in e85 for my customers for more than 3 years now.
there are one in a hundred walbro's that i've sold that gone bad in few months.
cant really tell what happen. it just wont pump as much flow as the working ones.
Old Jul 13, 2012 | 07:55 PM
mtber's Avatar
Never let a car sit for long periods of time with e85 in the fuel system...
http://www.injectordynamics.com/AlcoholArticle.html
JDM turbo DC
Nov 8, 2005 05:51 PM
snoochtodanooch
Dec 24, 2004 03:22 PM
speedymon
Nov 10, 2003 04:50 AM
Brian_92GSR
Oct 25, 2001 11:27 AM
