Transmission & Drivetrain Gearboxes, Differentials, Clutches
Rebuild S40 or buy used?
Old Jul 11, 2012 | 03:45 PM
FearSC549's Avatar
Default Rebuild S40 or buy used?
I have a 00 EX with a S40 b000 trans and I believe the bearing are failing (pilot, CS bearings, ISB). There's always a strong tug every time I shift gear and give gas, and a vibration/buzzing sound when the clutch is not engaged while in neutral. 2nd gear is also hard to engage at high RPMs (only 2nd, not other gears), which IIRC is something to do with the CS bearings. It has approx 150k miles. I'm tired of the noise, tugging, and also my clutch is worn out. Should I buy the same tranny for $300 with 107k miles (no rebuild), or rebuild mines? Also, how much would a typical S40 tranny go for (at parts place, junk yard, etc.)?
Old Jul 11, 2012 | 04:36 PM
Aquafina's Avatar
Default Re: Rebuild S40 or buy used?
Rebuild it. Never know what you're getting when you buy a used trans.
Does it pop out of 2nd?
The tugging is likely due to the mounts.
Old Jul 12, 2012 | 08:25 AM
FearSC549's Avatar
Never popped out of any gears, where should I buy my rebuild kit? Synchrotech?
Old Jul 12, 2012 | 09:44 AM
David @ Synchrotech's Avatar
We have rebuild kits or complete remanufactured transmissions.
I will PM some prices to you.
Old Jul 12, 2012 | 09:43 PM
FearSC549's Avatar
Actually I might just replace the 2 shaft bearings and find a used clutch at the junkyard in good condition considering I'm going to do a swap soon; imo pointless in rebuilding.
Old Jul 12, 2012 | 09:44 PM
zcegdx's Avatar
Used clutch from junkyard is a bad idea
Old Jul 13, 2012 | 04:39 PM
FearSC549's Avatar
So should I just get a new clutch, or where should I find a used clutch that's in good condition?
Old Jul 14, 2012 | 01:20 AM
92civiceg9gsr's Avatar
Just rebuild your working trans... it will be better in the end. An Exedy OEM replacement clutch can be bought for around $100 new.
phucheneh
Jan 6, 2013 11:06 AM
MrMug3n
Feb 24, 2010 01:47 PM
MrMug3n
Feb 22, 2010 01:38 PM
EnzoSpeed
May 11, 2005 01:22 PM
tunedek
Jun 16, 2004 03:14 PM
