Honda CR-V & Element 2WD & 4WD Element & CR-V
07' Element SC 5spd Manual Leaking Input Shaft(s)
Old Jul 11, 2012 | 04:54 AM
ndccpf1's Avatar
Default 07' Element SC 5spd Manual Leaking Input Shaft(s)
Tranny is leaking "internally" and the oil is dripping down the middle of the tranny onto the ground. The two axle input areas are clean and dry. Where else can tranny fluid leak out from to the ground (alot) if not from the axles, drain or filler plugs ?
DA9Teggy707
Jan 1, 2011 07:10 PM
rugimpy
Sep 4, 2010 04:00 PM
shadohconspiracy
13
Nov 4, 2007 08:32 AM
Pele
Mar 3, 2003 09:05 PM
