civic idle problem
Old Jul 10, 2012 | 02:38 PM
dodger's Avatar
Default civic idle problem
i have a 94 civic with a d15b7 ran perfectly fine before recently swapping out the auto trans for a 5spd. only thing on the longblock that i scrapped was the stock intake and intake mani if that makes anydiffrence. its running a skunk2 mani with the orginal iavc and tb. never had problem having it on my prev motor. but car form cold start has a idle surge all up until then needle is at exact were motors warmed up then is fine besides it having a surge on some sort in low rpm when taking off and trying to low rpm drive. like doing 20 in 2nd or 3rd gear it jerks the whole car around in surging but then if stoped its fine. any ideas??
Old Jul 10, 2012 | 02:50 PM
turbohatch96y7's Avatar
Default Re: civic idle problem
Your running a ecu from a manual car right?
Did you convert the iacv from 3 wire to 2?
Old Jul 10, 2012 | 03:36 PM
dodger's Avatar
i switched to a manual yes and what u mean about the iacv arnt they the same?
Old Jul 10, 2012 | 03:40 PM
Nope automatic should be a 3 wire google it I'm not 100 percent
Did you use the same wire harness??
Old Jul 10, 2012 | 04:13 PM
dodger's Avatar
yes sir
dodger's Avatar
also was just told the throttle bodys are different??
Old Jul 10, 2012 | 04:43 PM
I'm not 100 percent sure on the throttle body if you used the same harness check if there's a 3 wire plug for the iacv.
I'm pretty sure that's your problem. Do you have a multi meter?
Also check for vacume leaks. Start the motor cover the throttle body with your hand if the motor doesn't die you have a leak.
knavishpear
Jun 19, 2018 11:25 AM
Brent1289
Feb 21, 2014 08:58 AM
scdarksol
Jun 8, 2003 12:51 AM
