Honda CR-V & Element 2WD & 4WD Element & CR-V
04 CR-V
Old Jul 10, 2012 | 04:48 AM
c1rican's Avatar
Post 04 CR-V
my crv has been overheating only when stopped, while drive the temp gauge stays normal. i changed the thermastat and its still orverheating, theres no leaks in my radiator and anitfreez flow straight through
Old Jul 10, 2012 | 05:11 PM
ARMED's Avatar
Default Re: 04 CR-V
check the fans... hot wire it to the battery and see if it works
put your ac to the max, blast it....all your fans (radiator) should turn on automatically...if not...then you know whats up
Old Jul 11, 2012 | 06:21 AM
c1rican's Avatar
Default Re: 04 CR-V
Thanks, I turned the AC on max and both fans did turn on.
Old Jul 11, 2012 | 06:56 AM
ARMED's Avatar
Default Re: 04 CR-V
when you say overheating does it go all the way up?
and when its running the temp will be fine? usually thats a fan problem...
hopefully its not the water pump....
TODAEG9
Mar 25, 2009 10:05 PM
TODAEG9
Mar 19, 2009 02:27 AM
bboixtc
Aug 13, 2007 09:23 AM
B00STED Si
Jun 26, 2005 09:14 AM
