F23 swap in EG, search and read before you do.
Old Jul 9, 2012 | 12:41 PM
vectorsolid's Avatar
Default F23 swap in EG, search and read before you do.
Just putting this out there.
This was/is, NOT an easy swap. There's lot's of speculation and lot's of "try this" with this swap. F23 on obd2 from 98-02 accord or odyssey van. into EG hatch or coupe on obd1.
Lot's of motor mount issues, 2 and 3 wire IACV issues, 4 wire hitachi dizzy with the external crank sensors on obd2.
Go ahead and find a wiring diagram for the f23 dizzy. That will point you down the path of complication.
Just putting it out there. This is not the same old "b16" swap. Read up, and be ready, this is not an easy swap with very little information and lot's of speculation. Just be ready, that's all I'm saying.
Old Jul 9, 2012 | 12:47 PM
nealnanoHX's Avatar
Default Re: F23 swap in EG, search and read before you do.
It is pretty common info that putting a F or H series into a Civic is not the easiest swap and there are clearnace, wiring and mount issues. Its not like putting a B Series into a Civic.
Old Jul 10, 2012 | 09:28 PM
ivan93egreppin210's Avatar
Swap the crappy head for an f22a6 head so you can use your stock harness and use the h23 intake manifold plus you get a better flowing head. Nonvtec obd1 d series dizzy bolts up perfect. extend your alt wires. Buy the Qsd h2b kit so you can use all your b series mounts, tranny, and linkages. Relocate map sensor so you can close your Hood. Grab a beer and celebrate your new setup. Cheers.
Old Jul 11, 2012 | 06:56 PM
hondasdohc's Avatar
It was hard the first time i had put the f20b motor in my four door eg took me a week making everything right. Overall the swap is easier to do when you know what your doing with wiring and converting the obd2 motor to obd1. I had an f20b an f22 and an f23 and g22 vtec in my civic within the past year. The swap is very easy now for me to do now but to start from scratch like cutting the shifter hole to fit the cables and the passenger mount is a bitch.
Old Jul 11, 2012 | 06:58 PM
hondasdohc's Avatar
Better off doing a f2b less **** to fab imo but i like my high compression f22 with its buddy M2L5 (the tranny lol).
Old Jul 19, 2012 | 03:07 AM
We ended up with a non-vtec d-dizzy in it. Funny how that worked out. But were having a LOT of trouble with timing. I'm starting to be of the impression that we are 90 degrees off on the plug wire rotation. But timing seems to only be off 55 degrees. I dunno, I'm kinda mind screwed right now, just super tired.
I'd love to just use the 4-wire hitachi dizzy and run some wires, but can't find a diagram for it anywhere.
Old Jul 19, 2012 | 03:09 AM
Here's the one we made.
Old Jul 19, 2012 | 11:43 AM
hondasdohc's Avatar
well when you look at the d series dizzy you have to know what is the no.1 piston i had that problem at first but then i opened the dizzy and found out my wiring was wrong. I have a d series dizzy right now on my setup works great it also has h22 coil and ingition control module in it they swap right out. My setup is f22 block f20b pistons and f23 head runs beautiful.
Old Jul 20, 2012 | 09:12 PM
kingofbattle909's Avatar
Is thIS h2b?
Old Jul 23, 2012 | 06:09 PM
Originally Posted by kingofbattle909
Is thIS h2b?
It's an f23 engine with a prelude H transmission. Technically an H swap, for all intents and purposes of fitment, other than the driver side mount doesn't work.
Old Jul 23, 2012 | 06:25 PM
ashb82's Avatar
what are your plans for this swap
Jason-808
K Series
Aug 9, 2017 10:24 AM
lango-H22
Dec 18, 2010 07:41 AM
jdmanglerking
Mar 26, 2010 09:00 PM
squezzzed_b16
Dec 17, 2006 05:55 PM
Honda-Hooligan
Dec 8, 2004 08:12 PM
