b20 help
Old Jul 7, 2012 | 10:15 AM
bchapm's Avatar
Default b20 help
i have a 2000 EK civic with a jdm 2001 b20b. it has a 2001 ls intake manifold and a 99 ls throttle body. i have the 99 ls ecu that went to the throttle body. my problem is that when im going down the road at like 3,000 rpms and push the clutch in the motor will stall but if i gradually bring the rpms down around 1,500 or so it wont die the rpms fall low then pick right back up. does anyone have any ideals on what i should do to fix the problem? the iac valve and tps is good and no check engine light is on Thanks
Old Jul 7, 2012 | 10:29 AM
grumblemarc's Avatar
The Grumpiest
Default Re: b20 help
What?
Old Jul 7, 2012 | 09:50 PM
bchapm's Avatar
the throttle body and the ecu came from the same car a 99 ls integra
Old Jul 9, 2012 | 07:45 AM
bchapm's Avatar
does anyone have any suggestions on what to do what i was tring to say with the ecu and throttle body is they came from the same car so i know the tps sensor is calibrated right with that ecu its never been moved or changed. thanks
Old Jul 9, 2012 | 08:07 AM
The Grumpiest
Get the ECU for the head, not the throttlebody.
EKFrankie
Mar 27, 2012 10:57 AM
Superdragr45
Jun 3, 2006 08:41 AM
acura2gq
Jul 20, 2005 07:22 PM
Eggman
Jan 18, 2002 03:13 PM
