99 Civic EX Wont go past 5000 rpms -- need help
I just bought a 1999 civic has y8 in it cant pass 5000 rpms its like if it redlines at 5 grand any ideas would help
Re: 99 Civic EX Wont go past 5000 rpms -- need help
I ran into the same problem when i did my swap
i recomment checking the tps sensor and the map sensor on the theottle body, maybe even the whole throttle body is messed up
so for starters try to connecting and disconnecting the ecu that might be the problem
if not try replacing the throttle body with a buddies to see if thats the problem
and if you can switch out the ecu and see if it makes a difference
Bakersfieldgsr
11-11-2007 05:57 PM
hatchonarun
03-29-2006 07:07 AM
silentblackhat
04-07-2005 10:12 PM
