my engine turns, but doesnt spark
Old Jul 7, 2012 | 06:49 AM
leon1990's Avatar
Icon2 my engine turns, but doesnt spark
after replacing my valves and assembling back the engine i put my civic in factory timing, turned the key and the engine turned but didnt spark. they told me it might have been the distributer, so i put a new dizzy, spark plugs, and wires. turned the key and the engine continues turning but doesnt spark. there is fuel getting to the engine, all wires have electricity flow...... what could be wrong, i need help!
Old Jul 7, 2012 | 07:02 AM
ndowens's Avatar
With the new dizzy did you get a new cap and rotor. Also if the coil hadn't been replaced check it as well
Posted from Honda-tech.com App for Android
Old Jul 7, 2012 | 07:21 AM
leon1990's Avatar
Default Re: my engine turns, but doesnt spark
the dizzy is new out the box, came with new coil, rotor, and the cap as well
Old Jul 7, 2012 | 09:28 AM
Former User's Avatar
Does the fuel pump prime?
Did you reconnect the G101 ground on the thermostat housing?
Any CEL codes?
Old Jul 7, 2012 | 01:00 PM
VtakSOL93's Avatar
Check ur spark plug gap. If ur getting power from dist. Through wires but no spark. Then ur gapping might be off. .044 is spec for most hondas. Ur on the right track. Fuel, spark, timing, with all that working its something simple but often overlooked or not considered when ur chasing an issue.
ex_ricer
Aug 14, 2008 02:14 PM
dskater411
Mar 28, 2008 09:36 PM
austinkli
23
Feb 7, 2008 12:57 PM
TyfinHX
Apr 28, 2007 01:57 PM
TOP END MS
Apr 2, 2006 04:55 PM
