Fuel pump only sometimes primes
Old Jul 5, 2012 | 07:58 PM
bsyeth's Avatar
Default Fuel pump only sometimes primes
I Just bought a 93 Civic EX auto. didnt run when I got it... Fuel pump is not turning on.
I put another ECU in it and it worked, but now it sometimes works and somtimes doesnt. Cant be another ecu issue????
There must be a short somewhere?
Last edited by Former User; Jul 6, 2012 at 10:39 AM. Reason: Post clean up after redirect
Old Jul 5, 2012 | 08:02 PM
Former User's Avatar
Default Re: 94 Civic/D16Z6 -- no power to fuel pump ??? HELP
Resolder your main relay.
http://techauto.awardspace.com/mainrelay.html
Old Jul 6, 2012 | 10:10 AM
bsyeth's Avatar
I guess I should have said: I replaced the main relay already, tried several, even took one out of a friends running driving car. Also took out the fuel pump and tested it.
I swapped out the ecu with a working one, and it ran great. But after a few starts and drives, it started doing it again, But its been intermittent now.
Old Jul 6, 2012 | 10:41 AM
Default Re: Fuel pump only sometimes primes
Correct^
Clean and tighten the G101 ground connection the thermostat housing.
Old Jul 6, 2012 | 10:56 PM
bsyeth's Avatar
Im going to go ahead and remove and clean ALL the Grounds, then check back...
Dustin19902
11
Nov 18, 2014 12:34 PM
01 LudeDude
Sep 29, 2011 06:08 PM
krysted9354
20
Apr 8, 2009 03:32 PM
crxowner
Oct 2, 2007 05:49 PM
bc matt
Apr 2, 2005 01:17 PM
