Civic Cluster Wiring (7th into 6th Gen)
I don't know who to ask for this; so I had to make a thread...
I've been looking at fitting other clusters into 6th gen Civics and really liked the look of the sedan 03-05 over the s2k & the integra clusters, which had me look up some diy's and wiring diagrams. For me to use it, can I use this diagram (03-05 Cluster swap into 01-02) and the 01-02 into 96-00?
Basically, there's only a diagram for a 01-02 into a 96-00 and a diagram for 03-05 into 01-02, can I simply make a 03-05 to 96-00 using both diagrams by combining them over?
https://honda-tech.com/forums/showthread.php?p=41431594
03-05 into 01-02
01-02 into 96-00
03-05 into 01-02
01-02 into 96-00
Thanks for the acknowledgement Ron. Hmm, I guess there's no way of knowing unless I try it then since there weren't any comments about it. I'll be back in a couple of months when I come across a cluster and try it out... but not giving up hope for an answer from somebody with experience or better knowledge of this
his temp gauge doesnt read.
personally Id rather lose the mph then the temp, I can guess about how fast Im going, I never want to guess how hot the car is though. Dunno if its specific to his wiring or all of them the temp gauges are messed up
There is a very simple fix for this, and it involves bypassing the digital front-end for the temp gauge (ie - connecting directly the analog portion of the gauge only).
I cannot remember where I saw this, but it was done, and some searching should give you the answer.
I'm needing a new cluster for my CRV so if i can get a hold of a 03-05 Civic cluster I will honestly attempt to swap. I actually need to resolder all my cluster pigtails anyway because the rats chewed it up so we'll see.
The reason why I mentioned the CRV cluster is because it's the same as the Civic. Here's a collage I put together if you're interested in more cluster options that bolt in
Attachment 519159
Attachment 519159
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/05-civic-cluster-ek-temp-questions-2780928/
This info is great too
Jst picked up a 05 cluster in red for 34 bucks of ebay
. ive wiried lots of clusters before but i hear there is some mods that need to be done to make the temp gauge working. any one have any insight as to the mod needed.
Thanks and i will post pics soon as i find harness plugs for it lol.
oh and a little teaser
Still working out alot of bugs.
Full write up to be done when wrinkels are ironed out.
. ive wiried lots of clusters before but i hear there is some mods that need to be done to make the temp gauge working. any one have any insight as to the mod needed. Thanks and i will post pics soon as i find harness plugs for it lol.
here's some info on the coolant temp gauge on the 03-05 cluster. it's not looking promising however :/
"Engine Coolant Temperature Gauge
The engine coolant temperature gauge is controlled by the CPU built-in the gauge assembly. The CPU receives coolant temperature information from the ECM/PCM via the multiplex control unit, The ECM/PCM receives coolant temperature information from the ECT sensor."
so it sounds like it works similarly to an s2000 or rsx cluster.
found this also. after reading through a bit of it i think it's clear why no one has come up with a simple solution to the problem at hand.
https://honda-tech.com/forums/tech-misc-15/s2000-ap2-coolant-gauge-k-lin-converter-2768013/
the only time i've seen someone with a functioning temp gauge on a newer cluster is when it was also used in conjunction with the newer ecu and multiplexer unit.
@CO671 it was 03-06 precisely
The only thing that might be a problem is that crappy temp gauge, no pics/schemes with wiring anywhere....
EDIT
saw the info about s2k temp....
EDIT
BlueIntegraBoy
351
Dec 29, 2015 08:32 AM
canyouhearmatt
Jul 24, 2014 08:59 AM
CO671
Audio / Security / Video
Jul 9, 2012 11:36 PM
manual123
Feb 12, 2009 01:00 AM
