Gen 3 Trunk Latch is not working, how do I open the trunk ?
well, my trunk latch is not working, I can hear the motor actuator is working, I am assuming the actuator rod came off the motor itself, which is an easy fix, BUT HOW DO I OPEN THE TRUNK IN THE MEAN TIME TO ACCESS THE ACTUATOR, if I can;t open it...
I look from the back hatch, and there is no way I can take the panel out to access it.
is there any emergency latch that can open the trunk in the event that this happened ?, like the sunroof, has a manual deevice to close it, if the motor is not working...
tia
stan
tia
stan
My friend's trunk latch doesn't work neither. He has to turn his key and latch at the same time to open the trunk.
i actually had a the same problem. The latch button in the back stopped working. It would go back and forth and not do anything. Turned out that the button was getting stuck in one position, causing the system to not respond. I sprayed some wd-40 into the space between the button. It works now
Hope this helps
Hope this helps
my hatch is stuck closed too...i would love to fine a way to get it open so i can fix it if anyone knows how...since the "vibration from my exhaust made the motor go out" supposedly...damn dealerships not fixin it under warranty
...anyways if anyone knows how to get it open i would appreciate it
thanks again
josh
...anyways if anyone knows how to get it open i would appreciate itthanks again
josh
lol....thanks a lot chris...i tried and it worked first try...i guess that is the manual way to do it if the motor goes out? anyways thanks again im all excited i can get in my hatch again
Insert Key... hold the little lever, and turn the key hard and pull it up.
Turn the key hard.
Turn the key hard.
norcal450
Honda Civic (2006 - 2015)
12
May 2, 2007 09:53 AM
