PR3 B16a head, Cheap 81mm CP pistons & Eagle Rods, B16A Block
OBD1 B16a PR3-3 complete head minus intake, distributor, & vtec solenoid. Was pulled from a running motor with ~80k miles, will need to be hot tanked as it was sitting and is oil stained. There is also a nick on the metal edge where the cam caps meet the head, which can be seen in the picture. I was told the wouldn't affect anything, as it is only on the corner.
Asking 375 shipped to Cont. U.S.
81mm 10.5:1 comp CP piton with Eagle Rods. Piston have around 10k miles on them. The valves did kiss the pistons some, but were reused after wards without problem. You will have to buy another rod for one of the pistons, unless you can machine the scratches out out the connector which are drom a spun bearing. You will obviously need new rings as well.
Asking 300 shipped to Cont U.S.
B16A Block, will need to be honed, mains are included. $100 pick up only
Only trades considered are Stage 3/4 clutch and fly wheel, or possibly a set of coil overs, maybe a set of 15'' rims if offered.
I'm Located in Baton Rouge, LA.
godnf8
Mar 10, 2005 10:05 AM
