Honda CR-V & Element 2WD & 4WD Element & CR-V
will b18 ls distributor fit b20 harness
Old Jul 2, 2012 | 11:17 AM
JOSEP.TM101's Avatar
Default will b18 ls distributor fit b20 harness
i got a b18 ls distributor it has the plug with the blue color how can i make it work with the harness in my 97 crv with a b20 obd2 the one with the white inside the plug??? is there any way that i can splice and rewire to make it work will i need anything else a new ecu or will it work fine?? will it bolt right up to the 3 holes?? besides the plug what else will i need to do??
Old Jul 14, 2012 | 12:45 AM
civilrant's Avatar
Default Re: will b18 ls distributor fit b20 harness
As in understand it, pretty the entire top half the the engine distrib included is the same as the b18b engine(minus the intake mani). meaning your LS distrib should work fine. You've probably looking at a difference between obd1 vs obd2 or between the 2 obd2. obd2 and obd2a (I think, been awhile)
I ran into the same issue with mine. But i'm using a GSR distributor. In my case the GSR distrib i got turned out to be bad, and I ended up using the internals from my stock b20, the whole thing was a major PITA.
There are a ton of diagrams on this site for rewiring it to fit with your plugs.
HTH
Old Jul 14, 2012 | 06:09 AM
HTH
in there any way u can post a link cuz ive been looking and i cant find the answer on how to rewire the plugss?? or is that even possible to clip the wire and rewire the b18 dizzy with the b20 dizzy plug??
Old Jul 15, 2012 | 01:16 AM
civilrant's Avatar
google search works better
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/obd2a-wiring-harness-obd2b-distributor%2A%2A%2Aquestion%2A%2A%2A-2868178/
https://honda-tech.com/forums/showth...972711&page=11 <-- best
http://www.hondacivicforum.com/forum...estions-78677/
http://www.pulsitemeter.com/obd2b/ob...g-diagram.html
enjoy.
Joacnel
Engine Management and Tuning
Apr 4, 2012 07:02 PM
Jwbetley
Feb 18, 2009 02:45 PM
zm_dawg
Oct 12, 2004 07:57 AM
philafelman
Sep 14, 2003 11:41 AM
HybridCoupe
Feb 17, 2002 12:50 AM
