some fab work i've been doing
Old Jun 30, 2012 | 01:18 PM
a267mm's Avatar
Default some fab work i've been doing
First intake i tacked up
intercooler piping
Old Jul 15, 2012 | 07:57 PM
RC000E's Avatar
Default Re: some fab work i've been doing
Gotta start somewhere. Isn't exactly pretty but...it works. I see a lot of dips, contamination and cratering but...practice makes perfect.
Old Jul 22, 2012 | 09:15 AM
2000CTRSi's Avatar
MAn you are moving right along into projects! Good job. Clean gti also
Old Jul 22, 2012 | 01:12 PM
Mr.Wonderful's Avatar
Nice start. Keep it up and you'll be onto manifolds before you know it.
xXSanderXx's Avatar
Not the nicest welds but it should work. Keep moving!
Old Aug 6, 2012 | 02:53 PM
erbavour's Avatar
Not bad man. What welder are you using?
Old Aug 6, 2012 | 11:42 PM
TannerS14's Avatar
Wire brushin the welds after? You sneaky bastard.
Old Aug 7, 2012 | 06:54 AM
2000CTRSi's Avatar
Everlast microtig 185
Old Aug 7, 2012 | 12:11 PM
karmadhi's Avatar
do you pressure test those welds? If not you should, be surprised where you find leaks.
Old Aug 12, 2012 | 05:42 PM
a267mm's Avatar
ill post some more pictures that was actually my first car to do some welding to i actually started to learn ill be redoing some of these welds cause i think i gotten way better, ill post some pics of the 2nd car am doing tomorrow
Old Aug 12, 2012 | 05:43 PM
a267mm's Avatar
LOL no i used them to clean that white stuff it leaves on polished pipes, anything else i can use to get rid of that?
Old Aug 12, 2012 | 06:54 PM
v8killaz's Avatar
true that
Old Aug 14, 2012 | 03:44 PM
a267mm's Avatar
ok this is the second car i started doing, ill be redoing the welds on the first car just cause i think am getting better as i go
Old Aug 15, 2012 | 02:57 AM
that-guy's Avatar
you need to clean those cast elbows REALLY well before welding them, which is why the weld looks so dirty
Old Aug 15, 2012 | 05:03 PM
v8killaz's Avatar
that or hes dipping his tungsten in the puddle.
i would try praticing on flat pieces. it looks like you have very little practice with alum tig from looking at those welds
Old Aug 16, 2012 | 02:18 PM
a267mm's Avatar
yes very little but am just getting the hang of it now am able to keep my hand steady as before i couldn't am a little inpatient for this but i think ill get better as i go
Old Aug 16, 2012 | 07:33 PM
SovXietday's Avatar
Haha, in my experience it doesn't matter how much I clean those damn cast elbows they never get clean.
Old Aug 20, 2012 | 03:50 AM
that-guy's Avatar
you have to make them as smooth as possible, damn near polish
Old Aug 22, 2012 | 05:59 AM
a267mm's Avatar
what are you guys using to sharpen the tungsten besides the sharpener?
Old Aug 22, 2012 | 06:47 AM
HickamHatch's Avatar
Bench grinder with a fine stone wheel
Old Aug 26, 2012 | 07:16 PM
a267mm's Avatar
ok aluminum is kicking my *** but i think i got the stainless pretty good, am looking into building my own turbo manifold what rod should i use it will be sch10 material ss, i know it has to be back purged and also heard to do a root pass if that's what it's called.then give it a pass with filler rod. anything i should know before doing this?
Old Aug 27, 2012 | 05:50 AM
that-guy's Avatar
make sure your bevels are good, and your pieces butt up really nice and tight. do as much fiddling as possible, don't rush it...use 309L filler rod
Old Aug 27, 2012 | 06:52 AM
mayfly's Avatar
looks better than some of my work. keep it up
Old Aug 28, 2012 | 02:51 PM
a267mm's Avatar
how much amp should i run?
Old Aug 29, 2012 | 03:10 AM
that-guy's Avatar
i would suggest that you buy about a foot of sch 10 straight pipe, cut off 2 small sections, bevel them and weld them up, and then keep on doing that till you are happy with the welds
