MiniMe!
Old Jun 29, 2012 | 03:11 PM
Julian.DeCoito's Avatar
Default MiniMe!
Hello World,
I am a novice when it comes to cars so im going need your help. I want to do a minime swap to my 00 honda civic. Im looking to buy a Z6/Y8 head so I need a rap sheet of the "what I need."
What I know about me car...
00 Honda civic
d16y7
OBD2
Thank You
Old Jun 29, 2012 | 03:13 PM
Former User's Avatar
Default Re: MiniMe!
Have you looked in the FAQs sticky?
Old Jun 29, 2012 | 03:31 PM
JuggerNaut-CTR's Avatar
Default Re: MiniMe!
Really no point in doing a mini-me swap...
most have a hassle w/ them cause they just cant seem to research, like you.
your y7 already has a z6 intake mani which is way better than the y7's original set-up.
Invest your money in a good cam and valvetrain w/ a tune and you'll be way happier w/ those results than a mini-me
Old Jun 29, 2012 | 05:31 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: MiniMe!
Go with the Y8 head if you can. That way you can at least reuse your distributor. Like Ron said check the FAQ above.
Old Jun 30, 2012 | 03:37 AM
Default Re: MiniMe!
Thank you. Like I said am a novice, new to fourms, but ideas like that make it better then research. But I will invest in a good cam and valvetrain w/ a tune, and move to step two from there.
Thank You
Old Jun 30, 2012 | 03:40 AM
Default Re: MiniMe!
Ill try my best to keep an eye out, but ill first try what "JuggerNaut-CTR" recommended. Thank You.
Old Jun 30, 2012 | 04:07 AM
Technical Hero
Default Re: MiniMe!
You can't tune an OBD2 ECU, you can only convert to OBD1 and then tune. Keep that it mind especially when considering your local emissions testing as converting to OBD1 in a lot of states would make it unable to pass. But I'll be honest the money you're going to put in that Y7 would be better served saving up for a swap or turbo. Just my .02.
Inb4 grumble
Old Jun 30, 2012 | 04:29 AM
grumblemarc's Avatar
The Grumpiest
Default Re: MiniMe!
Read the link in my sig. Don't waste your time with that engine. Period.
Old Jun 30, 2012 | 06:47 AM
Default Re: MiniMe!
Thank You
If your desire for fast answers results in you taking random advice because you wish to avoid doing the necessary research and reading, you will surely end up with disappointment and also waste a lot of money. /thread
RaistlinJDM
Sep 13, 2013 06:00 PM
2manytoyz
17
Apr 15, 2012 07:20 AM
rellis
Aug 1, 2010 11:13 AM
CaptinMcnut
Mar 9, 2005 05:38 PM
scratchy
Oct 10, 2003 01:52 PM
