FS: EG hatch K20 turbo (chicagoland)
Old Jun 28, 2012 | 11:33 AM
Psychoteen101's Avatar
Default FS: EG hatch K20 turbo (chicagoland)
Testing the waters on this as of right now. I am in no need to sell the car, just thinking about starting a new project.
Car is a 93 civic CX. Body was originally white, i have repainted the car inside and out the right way! Everything was removed down to the bare shell for paint. New windshield was intalled as well as all new OEM window trim front to back. Only trim missing is the door window trim which i cannot locate brand new to save my life. I only used top notch paint products all the way down to primers and prep materials. Only thing the paint needs is a final wet sand and buffing. I never got around to doing that. This shell is beyond rust free! Cleanest ive seen for the area. When i stripped the car for paint, there was no patches or filler anywhere. I used minor body filler to fix small dents. I can actually provide evidence of this through my Build thread. I advise if you are seriously interested in the car to read through it entirely so you understand the amount of effort it took to get this car where it is today. While under construction, i also did a brake line tuck and completely shaved the engine bay of any uneccesary holes to give it a clean look. The entire bay has been stitch welded for rigidity.
https://honda-tech.com/forums/appearance-build-threads-122/picking-up-where-they-left-off-56k-warned-k20-eg-turbo-2673486/ <-- Link to build thread
Engine:
-K20z1- Type S
-Darton Sleeves-
-9:1 Je Piston w/ Crowler Rods
-Ferrera Valves/ Retianers/Dual valve springs
-Golden Eagle head Studs
-Has Sport engine mounts
-Hondata K-pro Ecu
-Hondata Intake Manifold Gasket
-Kong Intake manifold
-Kong Top Mount Turbo Manifold
-Kong I/c Pipping
-Kong Down pipe
-Kong Blow down Tube
-Kong Stainless Stee Upperl radiator hoses- upper/lower
-Kong IAC relocator adapter
-Kong Triangle Catch Can
-Kong Battery Trey
-Kong Engine Harness
-Precision Turob Sc6262 SP Billet wheel
-Precision 1000 cc injectors
-Precision 700 hp i/c
-Tial 44mm wastgate
-Tial BOV
-255 Walbro Fuel pump
-New OEM Timing Belt
-New OEM Water pump
-New OEM chain guides
-New Oem Chain tensioner
-Oil Pan, Brand new threads welded on oil return line for turbo
-C/R radiator with fan for RSX
-Thermal Exhaust stainless steel 3" piping
-Ceramic coated turbo housing/down pipe/turbo manifold/Blow down tube
Drivetrain:
-Rsx base model 5 speed trans
-All new Syncros
-Aluminum Flywheel Compettion clutch
-Stage 4 Competition clutch
-Gator axles- rated at 500 whp
-Quaife LSD
-Karcept shifter Bracket
-Rsx shifter cables/shifter box
Suspension:
-Tein Flex coilovers w/ EDFC
-Kong traction bar
-Function 7 camber kits
Brakes
-GSR front brakes w/spindles. Hawk pads
-Rear disc conversion from 00 si
-rear ep3 4x100 10.2 rotors with rsx calipers
-hawk street pads
-4040 GSR proportion valve
-New Rear Rotors
Wheels/Tires:
-15x7 Rota Grids powder coated
-Firehawk wide ovals up front, Falkens in the rear
-Burnt Chrome Lug nuts
-Comes with set of M/H slicks dismounted. 24.5x8x15
Body:
-Carbon fiber Wing (prvious owner states it was a spoon!)
-Vis carbon Trunk
-OEM Mud Guards
-Oem front bumper
-Vision carbon mirrors
-Momo Monte Carolo 320mm wheel
-NRG Gold Hub/quick release
-Oem Honda Jdm Arm rest (Wrapped in red tweed)
-Oem Honda Jdm center counsol
-Driverside/Passenger Side Door panels Wrapped in DGK T shirts
-Tein Hood Damper
-OEM TYPE R DC5 Valve Cover
-Spoon rear lower tie bar
-Itr shift boot- red stitching
-OEM Stanley Corners- New
-JDM EG6 Headlights
-SKunk2 shift **** weighted
-Buddy Club racing seats with buddy club super low rails (i also have the OEM seats)
-Takata racing harness' for both driver and passenger
Tuner - King Motorsports of New Berlin, WI
Numbers---
385WHP 285Ft lbs torque at 13psi - Wastegate spring
460WHP 340Ft lbs torque at 18psi
570WHP 440Ft lbs torque at 28psi --- 112 octane race gas
The highest HP it saw on the Dyno was around 650WHP and a little under 500ft lbs of torque (35lbs of boost)
I have never ran it higher than low boost since its been tuned!
I have ran it at the track a few times, best time out of it so far was an 11.5 at 125mph. Mind you that is on a drag radial at 13lbs! This car on a slick with some more boost will run deep into the 10's no problem.
Car has fuly certified 8 point role cage done in chromoly proffesionally installed by Tucci Speed shop in Grayslake, Il
Cage is certified to 8.49 1/4 mile. Was done in 1 3/4" piping which is NASA and SCCA legal.
Just recently I Pulled the motor and transmission to do some minor repairs. Transmission was rebuilt with a new 3rd gear and syncro, OEM honda
I also redid the timing cover gasket, oil pan gasket, vtec solenoid gasket, and valve cover gasket. As well as adjusted valve lash to spec.
I take care of this car and dont half *** any work as you can probably see. So much time and money has been invested into it over the years. This car has never once broken down on me or given me severe motor problems! Oil pressure is always solid nd it runs strong. I drive it fairly often when the weather is nice. I dont drive it in the rain and the car has never seen a winter! Garage kept and stored in the winter months. The only issues ive had with this car involve the trasnmission. I have since changed my driving habits which has helped alot.
Like i said before, i do not need to sell the car! Im just puting it out there to see what happens. I will not tolerate low ball offers. This car has well over $30,000 in modifications and upgrades, probably more if i include labor. I DO NOT want any offers for trades.
Im asking $12,000 (firm). Mind you this is a turn key race car! And by low ball, anything offered under 10K will not be taken seriously. If you cant afford it, dont ask!! I will not accept money grams, western union, personal checks, or monthly payments. Only Cash or a certified money order. Any offers for anything other than those 2 methods will be taken as scams and reported to honda-tech.
I Will not give out joy rides. If you have money in hand, i will take you out for a drive, I will not let anybody drive this car! If you want to look at it, i will meet you somewhere in a populated area during the daytime, I wont let anyone meet at my house and nothing after 8pm. Im not going to drive the car out to you, I dont want to go more than 15 miles to meet up. If you are interested, im sure that shouldnt be an issue. I wont ship the car over seas or to different countries. I will not take offers over the phone, only in person. I can deliver the car or trailer it to your location if purchased but anything farther than 25miles will cost a little more, if trailered. Im located in the North Eastern suburbs near the WI border. Ill post a few pics in this thread. I have literally hundreds more in the build thread. Enjoy and please BUMP if viewed!!
Old Jun 28, 2012 | 11:55 AM
gsrlee's Avatar
Default Re: FS: EG hatch K20 turbo (chicagoland)
bump for a badass eg, couldnt keep my eyes off of it at kings dyno day this year!
Old Jun 28, 2012 | 01:05 PM
SLUGONAEK's Avatar
sickk
Old Jun 28, 2012 | 01:15 PM
forcfedcivic's Avatar
Bump......bad ***......
Old Jun 28, 2012 | 05:12 PM
wyte_rice's Avatar
bump
Old Jun 28, 2012 | 06:41 PM
Turbo02si's Avatar
seen the car in person beautiful car. bump for you!
Old Jun 28, 2012 | 08:05 PM
maxwellmercer's Avatar
Followed your build thread, great attention to detail.
Old Jun 29, 2012 | 09:55 AM
DavisC22's Avatar
bitchin! this looks good.
Old Jul 2, 2012 | 07:53 AM
Bump! I suppose ill look into trades depending on what it is. Some examples would be a 240sx, has to be s13 coupe or hatch. Or other rear wheel drive cars. Let me know what you got!
Old Jul 5, 2012 | 09:08 PM
UP
Old Jul 5, 2012 | 09:21 PM
Midori.EK9's Avatar
bumpppppp remember following this build a year ago or even longer . remember it was white with orange wheels correct ? goodluck on sale bro very inspiring build you had .
Old Jul 15, 2012 | 05:10 PM
white with black wheels, then gold wheels. It was a hell of a build. Mostly learning process. I have an EF sitting that im gonna build next and it will be twice as detailed as this car was. Bump!
Old Jul 15, 2012 | 09:33 PM
AznRicer123's Avatar
bump
Old Jul 15, 2012 | 09:57 PM
B18 Piston's Avatar
siiiickkkk
Old Jul 17, 2012 | 05:41 PM
93dajjdg's Avatar
bump for a sick car
Old Jul 21, 2012 | 02:05 PM
Bump
Old Jul 27, 2012 | 04:23 PM
Up
Old Jul 27, 2012 | 07:57 PM
Firefighter4662's Avatar
Massive turbo
Old Jul 29, 2012 | 08:18 AM
hatch_wanna_b's Avatar
bump for a wild ride.
Old Jul 31, 2012 | 05:54 PM
Thanks gents!
Old Aug 1, 2012 | 07:17 PM
Jdmbryan's Avatar
j swap hatch? prob. not check my threaad
Psychoteen101
Dec 3, 2012 03:39 PM
H22Stew
Paint and Body
Mar 23, 2008 11:35 PM
nikolai.
Sep 4, 2007 04:31 PM
dunkd
Northeast (Sales)
18
Jun 13, 2007 04:18 PM
