New guy needs help
Hey guys. Working on my daughters 95 accord (4 cyl) While replacing the heater hose, I snapped off a 2 prong connector that sits directly below the distributer. the connector is ok but I need to replace what ever sensor that is. Does anyone know what it is? I now get a check engine light with a flashing D3 if that helps.
If anyone knows or if you could direct me to a diagram, it would be greatly appreciated.--Chad
when i need to find a part i use http://www.hondapartsunlimited.com/
it has blow up diagrams with all the part names. Maybe it can help you too
the sensor that your talking about sounds like its the vss(vehicle speed sensor) which is located right under the distrubuter. have you tried driving the car and if you have, does the speedometer go out or it works???
Thank you.
After looking at the exploded view, it looks like the TW sensor 37870-PK2-015 SENSOR ASSY., WATER TEMPERATURE (HADSYS)
I'll double check it when I get home.
Thank you for your help guys. I'll let you know if thats it.
Nonio
Sep 8, 2010 04:05 PM
mkim0801
Feb 6, 2006 11:55 AM
