b18b swap into ek coupe
Old Jun 25, 2012 | 07:12 PM
JOEUNIT96's Avatar
Default b18b swap into ek coupe
hey everyone,
i am putting in a 98 jdm b18b with a type R tranny into my 96 civic. i am keeping non-vtec so i got a 97 civic dx wiring harness. i am running hondata s300 soo this means i have to run a obd1 ecu, which i got out of a 95 integra P75. i have the jumper harness already.
what do i need to do to make this run right and drop into my car? i know i need the T braket and timimg belt braket off a 99-00 si and i have got motor mounts too. mostly i need to know wiring with the IACV 3 to 2 wire sensor. i have spliced in the 2 wire sensor but was not sure about the ecu side for the wiring. would i need to do something for my crank sensor?
would the shift linkage that i got with the swap work or do i need different linkage?
and if there is anything else i should do...
Old Jun 26, 2012 | 01:30 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: b18b swap into ek coupe
CKF bypass
http://technet.ff-squad.com/ckftrick.htm
Also the IAT won't plug in from your car to the ITRs IAT. You can just make a hole in your intake, use a PVC grommet and plug it in.
Run the wiring for VTEC and knock sensor as well.
Arthas
27
Aug 17, 2010 08:42 PM
hotcivicsi
Jan 8, 2009 06:50 AM
Blabla01
10
Nov 5, 2005 01:54 AM
nwisehart
Apr 26, 2003 05:52 PM
bOOsTiNSoHcVtEc
Feb 18, 2003 12:14 AM
