How do I take off my roof lining?
cool how did you mount it there?
Edit: dont see where you want to run it through, just go down the A pillar by the windshield, you can do that by using a screw driver to seperate the plastic from the glass (not acutally attached just really close together) then run it where ever you need...
Still Confused...but i hope that helps
[Modified by AcuraRacer112, 5:14 PM 10/18/2002]
unfortunatly the wires arent long enough to run it down the driver side. I currently have it taped to the window between the headliner and the windshield. I then have it running inside the pillar on the passanger side. No slack left. The reason why it wont work going down the driver side is because i have to backtrack about a foot. and a foot is too long.
I used the stand that came with it to mount it to the glass. I then painted the back of it black so you cant see it from the outside. plus when the visor is down you cant see it in the car.
whoa ****! thas krazy, i WOULD do that but i'll get jacked for sure, plus cops are probably gonna pulled me over a lot more! nice though, jus not practical for me. eitherway,
uhh you cant see it when the visor is down... you also cant see it from outside. its much more hidden than before. It used to bling when it was in the gauge cluster area. The ride height of a cop car is to high for them to see it.
I found out how to do it and got it fixed. the only problem is I shattered my front tooth taking the mirror down. I've got to get my tooth replaced on tuesday.
[Modified by Aeka GSR, 11:11 PM 10/18/2002]
now that's what i call dedication.
yup, broke my tooth. luckily it doesnt hurt. But I sure look like a hick if i do a little jig while a smile. I hope this doesnt cost me my first born.
mikess06
Acura TL, RL & ZDX
Mar 24, 2008 08:12 AM
Briman2021
Jun 1, 2003 03:48 PM
