Del Sol Rebuild. No start? Shit......
Old Jun 25, 2012 | 09:59 AM
Nate Case's Avatar
Default Del Sol Rebuild. No start? ****......
I just got my d16z6 all put backtogether. heres what ive done to it
New pistons and bearings
Bore out the cylinders
New oil pump
new gaskets
Dumped some oil in it and went to fire it up, It cranked over a few times
Now it wont crank over at all.
I thought it was the alternator belt to tight. Not that.
Then i felt my starter and iot was really warm.
What does this mean??
Old Jun 25, 2012 | 10:09 AM
Dc4LsTeG's Avatar
EK9
Default Re: Del Sol Rebuild. No start? ****......
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/
Old Jun 25, 2012 | 10:20 AM
Former User's Avatar
Are you able to turn the engine counterclockwise from the crank pulley bolt?
Old Jun 25, 2012 | 10:45 AM
Nate Case's Avatar
i could before. now when i try to turn it it just gets real tight
Old Jun 25, 2012 | 10:47 AM
Sounds like a problem with the engine build. You may need to remove and tear it down again.
Old Jun 25, 2012 | 10:51 AM
Dc4LsTeG's Avatar
EK9
Did you measure your bearing clearances? Did you have the p2w clearance done correctly?
Old Jun 26, 2012 | 04:31 PM
Nate Case's Avatar
Dropped the Sol off at the shop. i quit. Im no mechanic
Old Jun 26, 2012 | 04:58 PM
Don't be too hard on yourself. Live and learn.
Old Jun 27, 2012 | 12:23 PM
Nate Case's Avatar
Yea, Found out. there was just a bad ground and map sensor. I can build a motor but not hook it back up right.lol
Old Jun 27, 2012 | 12:29 PM
JuicedUpRice's Avatar
i use colored zip ties to color code everything before i put it all back together.Just some advice if you decide to do it again sometime
Old Jun 27, 2012 | 12:36 PM
How would this^ prevent the engine from turning?
gunrok
Dec 24, 2015 03:34 PM
mooney8289
13
Aug 3, 2013 12:54 AM
MrMug3n
Nov 25, 2010 11:26 AM
jdm-lov3ej1
Aug 11, 2010 09:11 PM
jachrist
Feb 5, 2010 10:46 AM
