ReSealing headlights?
Old Jun 25, 2012 | 09:28 AM
DJDriver88's Avatar
Default ReSealing headlights?
I had a pretty nasty leak into my stock ones and I broke the mounting clip thing that holds the bulb in place so I ordered black eBay Diamond lights (just OEM look but black housing). Would it be a good idea to go around the whole headlight seam with extra sealant before installing or are they generally OK quality wise?
Old Jun 25, 2012 | 09:31 AM
98civdx's Avatar
Master Detailer
Default Re: ReSealing headlights?
Yeah, I would...
I had that issue with my old Ebay lights, they leaked like crazy.
Old Jun 25, 2012 | 09:06 PM
jbpnoman's Avatar
If you decide to reseal them, as much as I hate to admit it, Nissan headlight sealant is MUCH better than Honda headlight sealant.
Old Jun 25, 2012 | 10:44 PM
all4kicks's Avatar
i would have to admit nissan sealant is better even tho i work at hnda
Old Jun 25, 2012 | 11:09 PM
furious94ls's Avatar
Don't open them up, but yes run a bead of sealant. I used clear RTV silicone on my black housings. You can see it a lil bit in the pic, You can't see it when installed. Either they never leaked, or with my clear silicone I don't have any leaks or even condnesation.
Old Jun 25, 2012 | 11:32 PM
ej6fade's Avatar
Since ebay headlights usually have crap sealant, I would suggest resealing them for the best results. Get some butyl tape (aka window weld) and reseal them. Heat the headlights in the oven at around 250 degrees for 7-10 minutes. Run the butyl tape around the headlight where the original sealant is, reheat same temp and time and make sure to go around the headlight and tighten it up with clamps after so the glue makes a watertight seal. I just retrofitted a set of ek9 headlights and have done others, butyl tape every time.
Old Jun 26, 2012 | 12:01 AM
98civdx's Avatar
Master Detailer
Yes, DON'T open them! They like to warp, ask me how I know.
Old Jun 26, 2012 | 12:26 AM
jbpnoman's Avatar
I don't know about all that. I opened my CTR knockoffs for my projector retrofit, and they didn't warp at all.
Old Jun 27, 2012 | 10:36 AM
DJDriver88's Avatar
Thanks for everyone's replies, I wasn't going to bake them, but just do an outer coat like you guys said
Old Jun 27, 2012 | 11:16 AM
98civdx's Avatar
Master Detailer
Well I do. They warped..
CubbyChowder
11
May 20, 2011 03:20 PM
jjr_99prelude
Mar 6, 2008 01:44 PM
hometheaterman
Nov 8, 2005 06:17 PM
crxcess
Jan 14, 2005 09:58 PM
cr2501129
Mar 26, 2002 11:06 AM
