Old Mar 25, 2015, 09:16 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
oil leak under distributor of JDM D15b - O-ring already replaced
Old Jun 23, 2012 | 09:25 PM
DCAR's Avatar
Default oil leak under distributor of JDM D15b - O-ring already replaced
i have a jdm d15b swapped 96 cx hatch. i have replaced the head gasket, the o-ring on the distributor, and the VTEC solenoid gasket. im still leaking oil from the passenger side of the motor. it looks to be coming from right under the dizzy. im a little lost now, what else could be leaking?
Old Jun 23, 2012 | 09:34 PM
Dc4LsTeG's Avatar
EK9
Default Re: oil leak issue
Valve cover gasket?
Old Jun 23, 2012 | 09:36 PM
furious94ls's Avatar
Valve cover gasket, VTEC solenoid, improperly installed 0 ring on distrib.
Old Jun 23, 2012 | 09:44 PM
DCAR's Avatar
sorry i did put a new valve cover gasket kit on. there is only one way to put the o-ring on....
Old Jun 24, 2012 | 03:40 AM
grumblemarc's Avatar
The Grumpiest
Did you use RTV sealant in the inside corners on the gasket?
Old Jun 24, 2012 | 05:23 AM
Former User's Avatar
It really sounds like a leak from around the O-ring.
OEM O-ring? Spread oil on it prior to installation?
Old Jun 24, 2012 | 06:50 AM
DCAR's Avatar
yes its a honda o-ring. that is the only place to get it. the oil isnt coming from the valve cover. all the oil is under the dizzy...
Old Jun 24, 2012 | 06:53 AM
Is there oil inside the distributor? If so, it's a bad internal oil seal. If not, the culprit is most likely the O-ring.
And there are many available aftermarket O-rings and it is possible to do a bad O-ring install.
Old Jun 24, 2012 | 06:56 AM
DCAR's Avatar
can those oil seals be replaced? how could the o-ring be leaking, its new?
Old Jun 24, 2012 | 06:58 AM
Yes
The O-ring can pop out of place or break during installation, especially if you don't oil it.
New is what you had when you bought the O-ring. Used is what you have after you install it.
Old Jun 24, 2012 | 08:04 AM
delsolintegra's Avatar
Default Re: oil leak under distributor of JDM D15b - O-ring already replaced
I had this same problem on my 93 del sol with D16Z6.
After I changed the distributor o-ring there was still an oil leak past the o-ring and I had used a Honda OEM o-ring.
What I did was loosened the distributor and backed it out of the block just enough about an inch to put a seal of silicon grease between the block and the base of the distributor where it touches the block. This was enough to stop the oil seepage. It's been good for over a year now. I got the silicon grease from a NAPA parts store, it's made by 3M. I use it on all rubber gaskets and o-rings now.
Old Jun 24, 2012 | 08:47 AM
axis11's Avatar
The internal oil seal is often neglected. After the outer o-ring is replaced, this is the only part left where oil can leak through the distributor.There is a small hole where the lubricating oil passes to return back to the engine. It can be easily clogged and so oil will accumulate near the oil seal. Cleaning this would prevent accumulation of oil but still sufficient to lubricate the shaft and seal. Oil leakage can be prevented or reduced depending on the condition of the seal.
Old Jun 24, 2012 | 10:44 AM
DCAR's Avatar
Originally Posted by RonJ@HT
Yes
no the o-ring still looks good. i have had it off a few times to inspect and no rips or anything. if i have oil inside the dizzy whats my options on fixing it?
Old Jun 24, 2012 | 11:08 AM
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/oil-inside-distributor-cap-2641435/
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-internal-seal-distributor-internal-oil-leak-2214402/
http://www.clubcivic.com/board/showp...4&postcount=13
Old Jun 24, 2012 | 11:12 AM
elsombradelsol's Avatar
There's nothing wrong with using a this film of form-a-gasket in addition to the O-ring, but it sounds like your internal might need a little inspecting.
djkurious
Mar 3, 2014 07:01 AM
D Griff
Nov 14, 2009 09:01 AM
JBthaboss
Oct 23, 2008 10:36 PM
Fat Chick Magnet
Nov 25, 2006 03:08 PM
95autocivic
Jan 9, 2006 06:00 PM
