Stripped Trans Bolts...
Old Jun 23, 2012 | 08:07 PM
EFS463's Avatar
Default Stripped Trans Bolts...
So maybe some of you have seen my other thread I just made about speedo cable, well I hit a much bigger problem. Everything besides the speedo cable was going pretty smooth with the trans removal, until I got to the rear transmission mount. The bolts were SO tight. It took 4 foot of leverage, 2ft breaker bar and 2 foot of pipe on the end to first break them loose but they came out hard the whole way. An impact wouldnt even move em. After 1.5 hrs i got the three bolts out, and when I got the trans out of the car I took a better look. Take a look at the bolt and trans below, the one bolt hole is cracked. What do you guys think is my best option for reinstalling this trans. I need to get it done tomorrow. Should I just try to run in the old bolts with an impact/ man power or should I use a repair method. Any recommendations!? All help is appreciate thanks in advance im in a big pickle right now
Old Jun 23, 2012 | 08:09 PM
EFS463's Avatar
Default Re: Stripped Trans Bolts...
I forgot to mention the guy who did the clutch before on this car must have cross threaded the bolts thats what it looked like to me and yes I did have the trans slightly jacked up before I tried to remove the bolts.
cracked case
bolt
Old Jun 23, 2012 | 08:21 PM
Mongo CRX's Avatar
Stripped out threads can be repaired by drilling out the hole and installing a heli-coil. Those cracks, though, are something else...
Maybe a pro could fix it, but I doubt it.
Old Jun 23, 2012 | 08:25 PM
EFS463's Avatar
Only one of the mounts is cracked. Think itll be safe with 2 out of the three bolts?
EDIT: in the event I do heli coil what size do I need?
Does anything think I should just try running those fasteners back in ?
Old Jun 23, 2012 | 08:46 PM
EFS463's Avatar
I'd like to add, I maybe be able to get a junkyard transmission.....what other year civics, and motor would be able to bolt right up to my d16a6 in my si? I am willing to buy a trans but I want to know what flexibliltiy I will have to find a trans? there is a 1990 civic with a 1.5 in it, will that trans work in my si?
Old Jun 23, 2012 | 08:55 PM
Mongo CRX's Avatar
That looks like the rear engine mount? If so that would be a 12mm bolt. Make sure the thread pitch matches the replacement bolt, and make sure you have the drill bit size the heli-coil kit says to use.
It looks like you were already driving with just two bolts holding down the mount, unless it cracked when you took things apart.
Old Jun 23, 2012 | 08:57 PM
Nickeg9Ej1's Avatar
if your not gonna try to make tons of power you can just run 2 of the 3 bolts just fine have a buddy that's running just one on his car he has no problems or anything funny... if you want a cheap fix clean the surface jb weld the cracks and tap the whole clean (forgot the tap pitch) install bolt and your done.
Old Jun 23, 2012 | 08:59 PM
Mongo CRX's Avatar
The trans is a bit complicated, they all take the L3 trans, but the DX, SI and HF all have different gear ratios inside. The 88 trans also had a different number of splines on the input shaft. I think the trans case is the same on all of them, though.
Old Jun 23, 2012 | 09:18 PM
EFS463's Avatar
Well Im gonna try to fix it in the early morning. I have never used a heli coil so I guess I will need to go out and buy a kit tomorrow. Does anyone else have a suggestion?
HotCheetos
10
Dec 11, 2010 09:07 PM
DumaDA
Mar 1, 2010 02:43 PM
lude98SH
Aug 26, 2007 05:32 AM
maynards_ek
Mar 7, 2007 05:47 PM
integration
Jan 6, 2003 08:13 AM
