Problem with my L-Bracket
Old Mar 1, 2010 | 09:59 AM
DumaDA's Avatar
Default Problem with my L-Bracket
The two bolts that go on the bottom of the L-bracket on my car are stripped, they fell out while i was driving and its causing the motor to rock back and forth. Would it be best to just rethread them a size bigger, i think they're 17mm, so should i just re thread to a 18mm or 19mm and use bigger bolts, or helicoil it and put inserts, im not sure how exactly to fix this problem. Any input guys?
Old Mar 1, 2010 | 02:22 PM
95 integra's Avatar
Default Re: Problem with my L-Bracket
On the 3rd gen they are 19mm....and usually it means it's time for a new trans case.
Old Mar 1, 2010 | 02:43 PM
DumaDA's Avatar
well i just switched the trans casing because the holes that the mount goes into were stripped, im just going to helicoil it , as long as i can get the bolts to stay in. The long bolt on top is a 12x61, and the bolt on bottom is a 12x31, so im going to get the helicoil kit and probably bring it up to a 13 or 14 and just put the insert into it. Im gonna head to the junkyard tomorrow and pull out the two bolts
Slacker93eg
Aug 10, 2012 05:05 PM
10HBmartian
Feb 3, 2012 06:55 AM
d_mina
Sep 15, 2004 02:47 PM
thinkbrianthink
Apr 20, 2004 07:04 PM
hybrid901
Jun 7, 2002 03:09 PM
