Fosgate P8002, P6002, P3 X 2, memphis audio 6X9 and amp!!! and a couple minor things
Old Jun 23, 2012 | 05:39 AM
S1n1SteR's Avatar
Default Fosgate P8002, P6002, P3 X 2, memphis audio 6X9 and amp!!! and a couple minor things
So guys need to clear my trunk for a roll cage to support 20psi out of a GT35R and need this stuff gone. This is all priced to sell so please do not low ball me.
On to the pictures and details
Rockford fosgate P8002 amplifier.
Product Specification:
General
Product Type Amplifier
Recommended Use Car
Width 11 in
Depth 17.7 in
Height 2.4 in
Audio System
Crossover Slope 12 dB/octave
Low Pass Frequencies 40 - 400 Hz
High Pass Frequencies 40 - 400 Hz
Additional Features Bass level remote control
Response Bandwidth 20 - 20000 Hz
Continuous Power / Channel Qty 200 Watts x 2
Bass Boost Frequency 45 Hz
Output Power / Total 800 Watt
Amplifier Output Details 200 Watt - 4 Ohm - 2 channel(s) ¦ 400 Watt - 2 Ohm - 2 channel(s) ¦ 800 Watt - 4 Ohm - 1 channel(s)
Amplifier Output 2-channel
Crossover 2-way active crossover
Bass Boost Gain 0 to +18dB
Display
Type None.
Connections
Connector Type 1 x audio line-out ( RCA phono x 2 ) ¦ 1 x audio line-in ( RCA phono x 2 ) ¦ Speakers output ¦ DC power input
Rockford fosgate P6002 amplifier.
General
Recommended Use Car
Width 11 in
Depth 16.4 in
Height 2.4 in
Audio System
Signal-To-Noise Ratio 80 dBA
Continuous Power / Channel Qty 150 Watts x 2
Output Power / Total 600 Watt
Distortion Factor 0.08%
Amplifier Output Details 150 Watt - 4 Ohm - 2 channel(s) ¦ 300 Watt - 2 Ohm - 2 channel(s) ¦ 600 Watt - 4 Ohm - 1 channel(s)
Display
Type None.
Connections
Rockford fosgate P3 2X12" subs.
Two of these bad boys in a custom ported box. Box included.
Diameter: 12 in
Voice Coil: Dual
RMS Power: 500 W
Nominal Impedance: 4 Ohm
Power & Sound
Total Peak Power Output: 1000 W
Total RMS Power Output (4 Ohms): 500 W
Sensitivity: 85 dB
Overall Min Frequency Response: 27 Hz
Overall Max Frequency Response: 250 Hz
Material
Diameter: 12 in
Cone Material: Polyether-ester - Surround
Cone Style: Cone
Voice Coil: Dual
General
Mounting Width: 11 in
Mounting Depth: 6.75" Depth
Warranty Information: 1 Year Limited Warranty
URL: Manufacturer Link
Crutchfield: Yes
Additional Specifications
Frequency Band: Cutout Diameter: 11.25" Mounting Depth: 6.75" Voice Coil Diameter: 2.5" 4-Layer Motor Size: 102 oz. double stacked Custom 10-AWG nickel plated push terminals Dual linear spider with embedded 16 AWG tinsel leads High-temp voice coil with spun-laced Nomex re-inforcement collar Protective PVC textured magnet cover Reversible diamond cut cast aluminum trim ring Vented spider cavity
Speaker Diameter: 12"
Sound Pressure Level: 85 dB
RMS Output Power: 500 W
PMPO Output Power: 1000 W
Speaker wires
Theres this and more that i havent gotten a chance to take out of the trunk.
Faux floor
If you are planning to throw this in a 6thgen trunk...
Memphis 6X9 speakers
Im not exactly sure the model or have much info about these atm since i am dead tired from pulling all the stuff out but if more info is needed, i will look it up.
Memphis audio amplifier
Again, dont have much info on this but i can look it up if need be
Sooooooo, now the big question of $$$. Im looking $800+ pp fee (if thats how you are paying) + shipping.
Included would be, 2 fosgate P3 in a ported box, P8002, P6002 and memphis audio amplifier, 2 6X9 memphis audio with crossovers and the faux floor that i used in my 01 sedan.
Can't ship the floor so that has to be a pick up.
Blue nology wires
asking is $50+shipping
thanks for looking
Old Jun 29, 2012 | 07:59 AM
S1n1SteR's Avatar
Default Re: Fosgate P8002, P6002, P3 X 2, memphis audio 6X9 and amp!!! and a couple minor thi
bump
alvinoolivas
Audio / Security / Video
Dec 7, 2010 09:01 AM
dustinO
Northwest (Sales)
Mar 16, 2010 02:16 PM
BKKloppenborg
10
Jun 18, 2007 04:41 PM
845_dapek
Dec 1, 2006 08:57 PM
happyman12
Feb 18, 2004 04:01 PM
