Do you think i warped my head?
Old Jun 22, 2012 | 10:45 AM
ejayeightb20's Avatar
Default Do you think i warped my head?
Yesterday i was doing a trial run around hear in my county. I had a long trip planned this weekend
and drove about 85 miles yesterday and luckly the radiator busted when it did and not like 100 miles into
the trip.i think the radiator didnt bust till i was close to my house i think. so thats a good thing.
i have a b20b with a y21 transmission and thats **** revs crazy high like 4000 and 80mph so i guess the pressure rised in the radiator and bam that **** busted. my question is do you think i warped my head driving like maybe 4/5 of the way up on the temperture gauge for about 7 miles tops could be way way less i saying worse case senerio
Old Jun 22, 2012 | 10:47 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Do you think i warped my head?
Do a compression test.
Old Jun 22, 2012 | 10:54 AM
aight if its like at 120 on all im good or is there a way to check
Old Jun 22, 2012 | 10:56 AM
The Grumpiest
Minimum healthy cylinder compression is 135.
Again, do a compression test.
Old Jun 22, 2012 | 10:58 AM
aight thanks alot man ill see if i can go find one
Old Jun 22, 2012 | 11:49 AM
Robin6's Avatar
yikes, why didnt you stop driving if you knew the rad was gone?
Aluminum heads only take a second to warp.
was there any oil in your coolant or coolant in your oil?
Old Jun 22, 2012 | 11:52 AM
Nooch's Avatar
Blast the heater when that **** happens, helps minimally.
Old Jun 22, 2012 | 04:45 PM
motegicivic's Avatar
All the way up, to the very top of the gauge? or like 3/4 up? 4/5 is not registering with me.
Sometimes if the radiator busts at the top seam it will not leak a lot of coolant, just puddle out, where did it break?
Old Jun 22, 2012 | 08:40 PM
i did a compression test 135 135 135 137ish. does that mean im good??? i did a pressure test on my radiator and it started squrting out the front like on the aluminium part so i changed it. but yall think im good with thoses reading? i hear that 190 is good and even 220 so idk if my b20 is ****ed up or just real low??? tell what yall think?
Old Jun 22, 2012 | 08:41 PM
like about 4/5 of the way thats the highest i saw it
Old Jun 22, 2012 | 08:42 PM
the coolant was thick but it didnt see any oil i really didnt check damn
Old Jun 22, 2012 | 10:59 PM
jbpnoman's Avatar
Your head should be fine, but it probably wouldn't hurt to flush your coolant system and do an oil change.
Old Jun 23, 2012 | 08:37 AM
thanks bro yea when i put the new radiator it only fit about 3/4 gallon and it was full i guess other coolant still stuck in engine
Cruisinga
Honda Civic (2001 - 2005)
24
Apr 12, 2012 06:25 PM
NubImports
Mar 18, 2009 10:09 AM
NightStalker
Mar 14, 2008 03:42 AM
djtony5
Oct 18, 2005 10:36 PM
jweller
Sep 25, 2003 04:27 AM
