P28 ECU problems
So I just moved and had to get an emissions test. Well I failed the test because my check engine light doesn't come on when you turn the key to accessory. Is the ECU my problem? Or is it just the bulb behind the cluster that is burnt out?
ls95hatch
Jul 17, 2003 02:13 AM
