Need Wiring help for 95 Civic Hatch brake lights
Old Jun 21, 2012 | 01:39 PM
Tommay's Avatar
Siruis is my hero. SIRIUSLY
Default Need Wiring help for 95 Civic Hatch brake lights
I tried to read through the FAQ section, and didn't see anything about this, so hopefully someone can help me out here.
I have a 1995 Honda Civic Hatch and my brake lights are inop. I have already checked all the fuses, bulbs, ect and I have made sure everything is plugged in correctly. They started not working a week ago. Before that, everything worked just fine. I washed the car, and after that they haven't worked. I'm running out of ideas to what could be the problem.
The wierd thing about it is my parking lights still work just fine. Everything turns on like it should, except for the brake lights.
Any and all help would be appreciated. Thanks in advance.
Old Jun 21, 2012 | 01:41 PM
Former User's Avatar
Default Re: Need Wiring help for 95 Civic Hatch brake lights
How did you test the fuse? Which fuse did you test?
Old Jun 21, 2012 | 02:04 PM
Tommay's Avatar
Pulled the #19 fuse, tested with multi meter. Then pulled every other fuse to double check everything.
Old Jun 21, 2012 | 02:59 PM
Tommay's Avatar
So I just checked it with a volt meter. I'm not getting power fron the fuse block underneath the hood to the brake light switch. If we put power to the brake lights, the lights light up. I don't get it :/
Old Jun 21, 2012 | 03:47 PM
The fuse for the brake lights is 20A hood fuse #42.
Old Jun 21, 2012 | 03:48 PM
Is fuse 42 blown?
Describe exactly what you did and what happened.
JAYDmManny1331
Sep 16, 2009 10:43 PM
MR Rodgers
Jan 5, 2009 02:32 PM
nguyen726
14
Mar 16, 2007 08:22 PM
EF Durty MX
Nov 8, 2006 05:57 AM
B00ST2nR
Jul 12, 2004 04:57 PM
