230-250 hp goal
Old Jun 20, 2012 | 06:04 PM
FrodeyEJ1's Avatar
Default 230-250 hp goal
This application is going on a b18b on stock internals, that i plan on dd. I'm wondering what size/trim turbo I should go with to reach my goal. or any specific brand. Also if this is safe on stock internals. Any info helps.
Old Jun 20, 2012 | 06:41 PM
TheShodan's Avatar
Moderator
Default Re: 230-250 hp goal
A GT3251B or a nice little T3/T04E 50 "trim" is all you need. Both are Garretts.. stick with that, and you'll be just fine. . Use a .63A/R T31 4 bolt housing for either one of those..
Old Jun 20, 2012 | 06:44 PM
FrodeyEJ1's Avatar
Thank you very much held my breath for an ******* response. Also I see your a top authority around here on turbos so thanks
Btw this isn't overkill is it? I mean would this be pushing the turbo hard?
Old Jun 20, 2012 | 06:50 PM
thomass's Avatar
No not at all. It wouldnt push the turbo hard whatsoever..the motor either. Just make sure you get a good solid setup with good parts and get it tuned...period.
Old Jun 20, 2012 | 06:55 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
wouldnt a T3 but just as fun?? fast spool time. from what i know itll work on a ls but choke out on a gsr
Old Jun 20, 2012 | 06:58 PM
FrodeyEJ1's Avatar
Will do thanks. Last thing how much do you think the turbo alone/full setup will cost. Is 3500-4000 a reasonable mental budget?
Old Jun 20, 2012 | 07:04 PM
Black R's Avatar
25 Year Member
For the most fun and response, I always look at the smallest turbo that will make the numbers you want.
On a boosted setup, you still want a little room to grow though so something between an evo big 16g and an 18g is what I'd look at (just based on personal experience).
Theshodan seems to know lot about turbos, so ofc I defer to him although I thought those recommendations seemed a little big for your power goals.
Research!!!
Old Jun 20, 2012 | 07:06 PM
thomass's Avatar
It really all depends on what brand name parts you want to get. Whether or not it will be New or Used parts. But with that budget you are very well opted to get some good quality parts to be a good reliable setup. Just Make a master list of all the parts you need..including the small stuff.
Old Jun 20, 2012 | 07:10 PM
FrodeyEJ1's Avatar
Thanks fellas
Old Jun 20, 2012 | 11:28 PM
civickiller's Avatar
i would just buy a go autoworks kit
Old Jun 20, 2012 | 11:32 PM
turbohatch96y7's Avatar
You should check out the drag section there's someone with a thread in there and has a stock ls with a 16g I think??
Anyway his setup is perfect I think for a stock ls and spools super fast and pulls all the way threw the rpm range.. check it out.
Old Jun 21, 2012 | 06:08 AM
TheShodan's Avatar
Moderator
THe 16G and Super 60s can work, though are limited in their approach in case he wants more. At 36lbs/min and 38lbs/min, they are a bit stretched to work with LS, unless at higher boost pressures. The only problem with the 16G is the integration into most manifolds mated to an LS; if you have the means to make it work, go ahead, but most of the time, they take a bit of time to get goin'. The Super 60 is a bit nicer, though a custom downpipe flange is made.
The go-autowerks kit is a good idea, though I recommend exactly what I said before if you decide to go that route. GT3251B, 50 trim, or Super 60 at the minimum
Old Jun 21, 2012 | 06:25 AM
blackeg's Avatar
What about a 57 trim with a .48 exhaust? Too far mismatched between turbine and compressor?
My first real turbo setup had a 57 trim with the. 63 exhaust, made 238/210 on 10 psi of boost on a 205K mile ls and it ran for about 25k miles before I went lsvtec. Not bad for uberdata lol
Old Jun 21, 2012 | 03:58 PM
FrodeyEJ1's Avatar
I'm looking to run 10lbs at most to make this goal because I would want to be able to get more out of it if need be. Also price is always a factor so knowing which is the cheapest route would help. Also a kit with limited customization is ideal. Any more knowledge is greatly appreciated.
Old Jun 21, 2012 | 06:11 PM
TheShodan's Avatar
Moderator
No. I do not recommend the .48A/R. The "spool" difference is not worth the effectiveness at slightly higher boost pressures over 10psi.
Old Jun 21, 2012 | 06:12 PM
TheShodan's Avatar
Moderator
Going the "cheapest" route unless you know exactly what you're getting into is the quickest way to not get the car going very far at all.
Old Jun 22, 2012 | 09:44 AM
FrodeyEJ1's Avatar
I can not find the gt32 for sale anywhere a link to a new one would be nice.
Old Jun 22, 2012 | 10:46 AM
boosted_D's Avatar
Go-autoworks tuner turbo kit with the 50 trim option.
chipped ecu+ fuel pump+ injectors+ good tune with neptune.
motor mount inserts, cc stage 2 or 3 clutch, boost gauge, ebay or custom 3" exhaust, test pipe or 3" cat converter.
$4000 well spent and complete.
torqueless
Feb 6, 2005 05:53 PM
steelies
Dec 27, 2004 08:27 PM
2fastcivic
Jun 17, 2004 09:16 AM
Neeko
Feb 9, 2004 10:28 AM
egg
May 2, 2003 04:30 PM
