starting problems on a 98 gsr..
Old Oct 14, 2002 | 03:45 PM
-BlueGSR-'s Avatar
Default starting problems on a 98 gsr..
Recently my car has been having weak starts...it takes a while to fire up...is this just a spark plug problem or battery problem?...and today when i started it...it would crank for a few seconds til it actually started...then when it fired up...it almost seemed like the engine was going to stall...the rpms dropped then went back up...the plugs dont look too bad...but probably need to be changed..and I had plenty of fuel..and it was a rather cool day..not too cold....any ideas on what could be up?
Old Oct 14, 2002 | 04:05 PM
Fuuma0083's Avatar
Default Re: starting problems on a 98 gsr.. (GS-ssbp-R)
how many miles do you have? You might need a tune up
Old Oct 14, 2002 | 04:13 PM
B18_C3P0's Avatar
Default Re: starting problems on a 98 gsr.. (Fuuma0083)
for all you know it could be something simple. get it checked out by someone else you trust!!1
Old Oct 14, 2002 | 04:34 PM
-BlueGSR-'s Avatar
Default Re: starting problems on a 98 gsr.. (B18_C3P0)
about 62000 miles or so...or 102k km....so i know the plugs have to be changed....and I only get these problems once in a while..very randomly...otherwise it starts fine...like most hondas!!....today was the only time it did the weird rpm idle....so ill get it checked...im still under warranty....any other insights??
Old Oct 14, 2002 | 05:48 PM
ALF's Avatar
ALF
I have the same problem...happens spontaneously too. I'm surprised it's happening to your car with it being much newer than mine. I have had this problem for almost 2 years already. I've tried lots of things. I'm starting to think the problem is from clogged fuel injectors since it's the only thing I haven't done any maintenance to. Then again, I get GREAT gas mileage. I'm getting 330 miles to a full tank with liberal amounts of high RPM driving.
Another thing it can be is a bad vacuum line.
Let me know if you find the problem.
[Modified by ALF, 9:48 PM 10/14/2002]
Old Oct 14, 2002 | 06:04 PM
-BlueGSR-'s Avatar
Default Re: starting problems on a 98 gsr.. (ALF)
ya i get great mileage also...with lots of stop and go traffic....ill let u know whats up....anyone else?
Old Oct 15, 2002 | 05:55 AM
mikeeee's Avatar
I have a 98 gsr with the exact same symptoms. Usually starts within a turn or two. It's usually when I turn it off and restart it after less than 15-20 minutes that it has problems. Like, at the gas station.
I just figured I am getting close to needing a new battery. Aren't stock batteries only expected to last 5-6 years? I live in Wisconsin, so I am sure our cold winters don't help either.
Old Oct 15, 2002 | 04:30 PM
John-GSR's Avatar
Default Re: starting problems on a 98 gsr.. (mikeeee)
Samhe here... I got a 98 gs-r and very similiar problems. Battery is ok but still might replace it, kinda old plus looking for a stronger battery. Might be fuel filter? Not sure but i was thinking that maybe that earth ground kit might help... Suppossetly, you get better idle, and better performance. still researching it though.
Old Oct 15, 2002 | 04:38 PM
Al Bundy's Avatar
Default Re: starting problems on a 98 gsr.. (John-GSR)
I got the same problems with similar mileage also.
Old Oct 15, 2002 | 04:46 PM
-BlueGSR-'s Avatar
Default Re: starting problems on a 98 gsr.. (OBD1KNOBE)
Hmmm...maybe its a common enough problem that its nothing big to worry about...??...
Old Oct 15, 2002 | 04:49 PM
John-GSR's Avatar
Doesn't bother me too much.. By the way I do have a new motor with only about 20k on it and it's still there. ahhaha.. I just think it's that small battery. Not enuff cranking power. More power
Carlsson
May 3, 2014 01:39 PM
fasteddief23
Jun 30, 2011 05:07 PM
mykey06
Sep 5, 2007 08:26 PM
sickntired
Jul 20, 2006 03:31 PM
Leftlaner
Jul 10, 2005 09:25 AM
