B16 Turbo or B18c5 w/89mm crank all motor?
I have both sitting in the garage. It'll go in a 93 DA.
the B16 is completely stock. The B18C5 has a B20 crank, Rods and usdm itr
pistons at 82mm. So which one should I go with?
I'm gonna go ahead and put my vote on the b16 turbo.Have you considered putting the head that is on the b18c on the b16 and then turbo?
Look i have a 12.5 b series on 10 pounds and runs great .. it all about the tuner, most people play it safe and do low compression... charge the b18 but put a block guard. by the motor being high compression relieves stress of charger make more power with less psi... no more than ten temp creates hot air . Now if its a turbo your placing in there then i suggest a thicker head gasket with arp stud to drop compression into the 11s and boost it .. Now its like boosting a k series
Awesome info. I was thinking of doing that too. It's just that those type of head gaskets have a pretty bad rep. Even with Arp's. And I don't really want to have anything to worry about, you know..?
i feel u.. cometic gasket will do just fine with arp... remember its all about the tuning.. make sure to have s300j it will really help you and the tuner to perfect your car
