Civic si 2000 won't start after removing plug wire
Old Jun 17, 2012 | 09:05 PM
kaison's Avatar
Default Civic si 2000 won't start after removing plug wire
I own a honda civic si (em1), and I am currently unable to start up my engine. Earlier today I replaced my short ram with a stock air filter that came off a b18c (jdm engine). In the process of replacing the filter, I removed a sparkplug wire from the distributor (because it was in the way). But anyways after the air intake was replaced, approximately 20 seconds after turning the engine on, it shuts down. I went to go check engine and realized I forgot to plug the spark plug wire back into the distributor... anyways I plugged it back in and tried to start the engine up again... but now the engine does not even start, it does crank though.
Please excuse my poor english/grammar skills, english is my second language.
-Thank you to anyone who is willing to assist me
p.s. I forgot to say that Check engine light is now on and I used OBD reader and the code that it presented was P0113
Old Jun 17, 2012 | 09:11 PM
doood's Avatar
been there done that
Default Re: Honda civic si 2000
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
unrelated to the plug wires. did you plug everything back in?
Old Jun 17, 2012 | 09:16 PM
kaison's Avatar
I have one wire that is not possible to plugged into a stock air filter. However the pcv valve and everything else is in. And I was wondering can air intake really prevent an engine from starting?
Old Jun 18, 2012 | 01:21 AM
HondaPartsHero's Avatar
Technical Hero
For the IAT do something like this
You probably fried your coil. Are you getting spark?
http://www.team-integra.net/forum/bl...eshooting.html
Old Jun 18, 2012 | 05:07 AM
Former User's Avatar
This^
A very efficient way to blow the coil is to unplug a plug wire with the engine running.
Old Jun 18, 2012 | 04:29 PM
kaison's Avatar
Default Re: Civic si 2000 won't start after removing plug wire
Problem solved, turns out I fried my ignition coil... advice to others, DONT FORGET TO REPLUG YOUR WIRES
Thank you very much fellas
Mistr Theodorik
Nov 4, 2017 11:48 AM
SVOHK
Jun 18, 2015 08:46 PM
mnskateboarder
Jun 20, 2008 11:52 AM
Bok Choi
Jul 24, 2006 10:43 AM
Allstar
10
Mar 28, 2002 07:04 PM
