1040 t1 trigger aem twin no rpm or stat sync
Hey guys hoping you can all help me out here. Im running a 1040 box with tonys cam trigger using a aem twin fire cdi and im getting no rpm signal in AEMPro when i tried to sync the timing. Along with the stat sync doesnt turn on. I know its most likely a wiring issue on my end (or so i hope) Im getting t2per to change during cranking along with crank tooth period which also changes but stat sync does not come on. I double checked the wiring for the twin fire as ive heard its common for them to have issues and noticed the red led doesnt turn on when the box has power. Is it suppose to or only come on when its sending a signal to the coils? I did check to double make sure its getting power with the key on and while cranking and it is. Im stumped and dont know where to go from here. Hoping to get the car tuned soon but idw to bring my wiring nightmares to a shop for them to deal with.
Yes I changed the cam/crank sensor options and such via the intstuctions provide from t1. Tried to log it again yesterday and now I'm not getting anything from the cam sensor. I'm trying to find a multimeter to barrow and see if it's even sending anything back underpowered. I'm thinking or more hoping its got I be the sensors just shot.
Alright got some more diag done today. Hand test the voltage reading of the poles with a magnet and im geting 4.9v at both poles so sensor is good. Plug back into ecu and its seeing a signal. No stat sync though still and i noticed the coil parameter never turns on. And the ignition charge lock parameter turns red (meaning and error?) and reads 255 if i remember. I am in no way a tuner so alot of this is by the seat of my pants and alot of reasearching lol any and all replys are very appreciated guys. Lets get this beast running!
we have the same problem
have you fixed yours?
im using 6040 and pro14. but this is irrelevant to our problem. i think something to do with setting of cam trigger in aem? are you using v24?
preludedude2001
Engine Management and Tuning
May 31, 2015 06:14 AM
hondaboy4life
Jun 27, 2011 02:19 PM
