Worn Crankshaft question
The front and rear main seals worn into the metal a little on my crankshaft. Are they worn too much or is it still ok? I know the picture makes it look like its deep, but the actual groove is not very deep, however you can feel it.
X2
there is always normal seal wear in these areas, and normally new supple seals have enough spring in them to make up for this difference, although the crank pulley side seems pretty severe, just hope the pictures are exaggerating the groove
Also it might just be the photo also but that keyway looks kinda gnar'd also
The photos exaggerate it a lot. It does catch your nail but it is actually very shallow. I was just wondering if I put a new seal on there if it would seal completely.
Take pictures very close up of each flat surface showing just how deep the valleys are, maybe using a backdrop of some sort that helps us determine wether or not to worry about it.
djfob
Dec 6, 2011 03:14 PM
