no fuel pump and spark HELP!!
Old Jun 17, 2012 | 09:06 AM
EG_SINZ's Avatar
Default no fuel pump and spark HELP!!
i was on the track yesterday and going around the corner and the car cut out and wouldnt start. didint hear the fuel pump , so thought main relay . when got towed back to the pits
swapped in a buddies main relay didint do anything . no fuel pump still . put in his ecu and nothing again . checked the grounds on the valve cover tranny and the thermostat
all fine and nothing still . checked fuses seem fine .
its a 95 del sol with gsr
please if anyone has any ideas pretty lost here
Old Jun 17, 2012 | 09:49 AM
Former User's Avatar
Default Re: no fuel pump and spark HELP!!
Double check fuses 31 and 24.
Old Jun 17, 2012 | 03:51 PM
EG_SINZ's Avatar
i dont have the diagram in the car but from the honda tech thread and looks like it only goes up to 25 ?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/civic-del-sol-fuse-panel-printable-copies-fuse-diagrams-here-1966666/
looks like on the diagram 15 n 24?
so went and switched those fuses they are totally fine and still no power
Old Jun 17, 2012 | 04:54 PM
Look for fuse diagrams in the FAQs sticky (Electrical section 17a). Check fuses 31 and 24.
Old Jun 18, 2012 | 02:40 PM
EG_SINZ's Avatar
thank u for the help drum rolll problem was
ECU fuse my buddy must of missed the fuse when he tested it but i spent 2 mins and looked tonight and boom there was the blown fuse. starts right up .
hes saying they all had the power at the ecu but i changed the fuse and its running now
what could cause this thats the next question
Old Jun 18, 2012 | 08:29 PM
streethondar's Avatar
Fuses do go bad just like anything else.. A loose ground could have caused it.. You said all your grounds were ok though.. but im just putting that out there. If it goes bad again soon then you have a issue somewhere.
wtfisvtec??
38
Jun 30, 2024 05:13 PM
pedroa06
Jun 30, 2013 06:43 PM
fordboy15
12
Jun 7, 2013 02:56 PM
killingtwobirds
Sep 17, 2008 12:45 AM
frost_0ne
Sep 13, 2005 01:02 PM
