Some questions about window molding/trim
As you can see in this picture (excuse the dirty car, there's a lot of pollen in the air here) the plastic molding on my Integra is damaged. It is damaged on both sides of the car. I would like to replace it eventually, but I have some questions before spending money on it.
1. I'm assuming the part numbers are 72410-ST7-003 and 72450-ST7-003 (MOLDING ASSY., L/R. FR. DOOR), correct?
2. Do these parts come with the black plastic that is on top of the steel piece, or is it just the steel piece?
3. If it is just the steel piece, how do you put the black plastic over it again? Where do you get it?
Thanks.
I got all that stuff at a pick and pull for $3.00. Good stuff to! You could also use a razor blade and cut all the rubber plastic stuff off and paint them. Good cheap fixes.
Sorry about that, it's a 99 3 door GSR. I really don't want to just tear it off and paint it. I'd like to keep it as OEM as possible. Unfortunately there are few pick and pull junkyards in my area, and what is usually there is garbage/destroyed.
If you want I can check at the PicknPull here in Kelowna, I am pretty sure the 94 Integra here has good doors and it is a black one.
It can't cost much to ship them to Connecticut. 94
crxaddikt
13
May 4, 2014 11:09 AM
VTEC IS UR BEST FRIEND
Dec 29, 2009 06:05 AM
gsr.sedan
Jun 7, 2001 01:36 AM
