bent valves. pistons ok?
Old Jun 16, 2012 | 06:04 PM
mayfly's Avatar
Default bent valves. pistons ok?
car 92 civic hatch.
motor stock b18b1
hey ht i was at the race track and miss shifted from 3 to 2. dumb mistake i know.
i pulled the head and am replacing it with a fresh head.
head is still at the machine shop getting valve guides, valve seals and springs put in.
so my question is when i pulled the head the valve in cylinder 1 had a next to nothing indent. it was a very slightly bent valve, but the piston had a new little groove in it at the valve relief from where the piston came in contact with it. its not much but something. will the new valves be ok when installed with these pistons? or is there going to be a issue with that cylinder? thanks
Old Jun 16, 2012 | 06:39 PM
98civdx's Avatar
Master Detailer
Default Re: bent valves. pistons ok?
Just a "light" groove? if that's the case you'll most likely be fine.
Can you post a picture of it?
I've seen cars be perfectly fine with a lot worse then groove in the piston. lol
Old Jun 16, 2012 | 09:24 PM
beecee18's Avatar
Smiley face on cyl # 1
A picture would help, but from your description, you should be fine.
Old Jun 17, 2012 | 06:30 AM
Padawan's Avatar
Darth ModerVader
Depending upon how significant the groove is, I would suggest polishing out any sharp edges as best you can to eliminate the potential for a hot spot to form in that location.
Old Jun 17, 2012 | 07:43 AM
mayfly's Avatar
i cant get a picture now because im in the marine corps and we have "hobby shops" that we can work on our cars and it is over there right now, and i probably wont be back over there till my head is ready.
and yes its a little smiley face. i appreciate all the responses gentlemen. this makes me feel a little bit safer about putting the new head on.
thank you
Old Jun 17, 2012 | 07:44 AM
mayfly's Avatar
what should i use for that? like a small 3m scratch pad? or like 1000 grt sand paper?
Old Jun 17, 2012 | 07:53 AM
beecee18's Avatar
Depends on the extent of the damage,
I'm used to using steps of
600
1000
mothers polish paste for aluminum and other soft metals
Old Jun 17, 2012 | 09:17 AM
mayfly's Avatar
600
1000
sounds good. ill do that!. thank you very much
mayfly
Jun 16, 2012 06:02 PM
Spawne32
Dec 21, 2010 08:47 PM
reformedricer
Aug 16, 2009 05:29 PM
lyckaon
Nov 20, 2005 11:05 PM
gsrjay
Sep 2, 2004 05:05 AM
