b20 turbo? 12's?
Old Oct 14, 2002 | 01:49 PM
yusoslo's Avatar
Default b20 turbo? 12's?
What's up everyone. I own a 95 civic coupe and its time for some speed. Money is a bit of an issue but not a major one. I was considering two options:
1) A stock b20 turbo
2) A ls turbo
Now i don't know how much more expensive a b20 buildup is, but I want to run very low 13's on street tires, or high 12's. This is very important to me, because my car will be on the street 99% of the time. I want to run stock internals if possible as well. I have been doing research and am considering not going vtec on the blocks. To me is seems like a waste of moneyif you are going turbo. If i could get any advice on a turbo trim (probably a t3-t4) or a junkyard (300zx). Also do you guys think the b20 is worth the extra cash, and how much if so. Like i said i want a reliable street car that will be very-quick. Thanks for any help or input.
Old Oct 14, 2002 | 03:01 PM
NoBoost's Avatar
Default Re: b20 turbo? 12's? (yusoslo)
how could u compare a t3/t4 to a junkyard 300zx turbo. 300zx turbos are tiny even smaller than a stock eclipse turbo. id go b20vtec. imo. i dont know the price difference though.
Old Oct 14, 2002 | 08:02 PM
B18PoweredCivic's Avatar
Id do ls turbo...b20 is a tough swap..You have to know how to wire it up and you have to change the manifold..LS turbo should get you into the mid 13s...b20 turbo will be a little more expensive because you will have to buy all the parts separtely..the b20 motor will be about 800 when an ls swap will run you 1500 from a junk yard with everything including ecu and tranny..If you have the time and money and knowledge go b20...if you want a quick good swap that you can boost high with...go ls turbo..besides its easier to find ls parts
Old Oct 15, 2002 | 07:22 AM
jinxproof99's Avatar
New User
5th gen civic coupe
stock b20b block
springs and retainers in a stock b20b head
inlinepro custom turbo kit
440 injectors
afc/fmu
drag radials
full interior w/baby seat
race gas
12.40's @ 115 mph.
Old Oct 15, 2002 | 11:28 AM
MikeMAN's Avatar
Default Re: b20 turbo? 12's? (jinxproof99)
5th gen civic coupe
stock b20b block
440 injectors
afc/fmu
drag radials
race gas
12.40's @ 115 mph.
there ya have it from the dude that USED to get wheelspin at over 100mph
mike
Old Oct 15, 2002 | 12:40 PM
SmoothVTEC's Avatar
1994 Civic hatch
b20/vtec(stock internals)
t3/t4 turbo
440cc injectors
stock ECU
VAFC
slicks
pump gas
12.2's and drove it home. it's my daily driver
Old Oct 16, 2002 | 12:15 AM
Mista Bone's Avatar
D Tranny Guru
jinxproof99/Jeremy...........
Someone willing to answer even my questions!
12's on a stock D block, who knows what on a B block for me!
Old Oct 20, 2002 | 03:18 AM
SSBP DC2's Avatar
Default Re: b20 turbo? 12's? (Mista Bone)
this question goes to the two guys who ran 12's
how long did you have the motor?
if it is gone...could you explain what happened?
thanks
demitri
Old Oct 20, 2002 | 06:07 AM
AussieK24's Avatar
Mista,
You don;t need no stinken B motor!!!! All those cams just get confusin hehehe
PS: When is this 12 comin???
Old Oct 20, 2002 | 12:33 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: b20 turbo? 12's? (b16a4me)
when I get some 97+ Lude injectors, stuck at 13.09-13.10 till then.
Old Oct 22, 2002 | 12:35 PM
xrtdac
Guest
Posts: n/a
LS Turbo
Full interior
Slicks
12.6 @ 110MPH (gotten as high as 114MPH)
DAILY DRIVER (made road trip there and back. Each way was 350 miles)
[Modified by xrtdac, 8:37 PM 10/22/2002]
Old Oct 22, 2002 | 01:46 PM
hawjdude's Avatar
Default Re: b20 turbo? 12's? (xrtdac)
B20 turbo with slicks you could hit 12s.
nightshift
Oct 15, 2009 02:13 PM
blufke
Oct 15, 2002 09:07 AM
rocket_R
Aug 24, 2002 11:06 AM
ZeRo
Mar 12, 2002 01:49 PM
