Honda S2000 Honda S2000
OEM Pistons with Cast Iron Sleeves
Old Jun 16, 2012 | 02:15 PM
buzz944's Avatar
Default OEM Pistons with Cast Iron Sleeves
can I run the F20C OEM pistons with cast iron sleeves?
or cast iron only works with aftermakret pistons?
my IP HG blew and water ate through my cylinder walls
Old Jun 16, 2012 | 02:18 PM
Boots's Avatar
Default Re: OEM Pistons with Cast Iron Sleeves
i wouldnt...id run an aftermarket piston with aftermarket sleeves
Old Jun 16, 2012 | 02:21 PM
buzz944's Avatar
I want the car to be stock,
how about just using stock compression pistons? will it work with OEM ECU?
Old Jun 16, 2012 | 02:28 PM
Boots's Avatar
will what work with the OEM ECU?...if you sleeve the motor, get aftermarket pistons...if theyre the same compression, you shouldnt run into any issues with the stock ECU
Old Jun 16, 2012 | 02:33 PM
buzz944's Avatar
and ofcourse i'll also need aftermarket rods + bearing & HG set right?
Old Jun 16, 2012 | 04:11 PM
Boots's Avatar
thats what i would do
Old Jun 16, 2012 | 04:36 PM
HondaKyle's Avatar
spend a little now. spend a lot latter. just do it right the first time. I really wish the price on S2000s didnt go down so much. Seems like everyone wants to cut corners to save a dollar now.
Old Jun 17, 2012 | 02:04 AM
buzz944's Avatar
I'm not trying to cut corners, we just have limited resources in my country
Of course this way i'll have a 100% fresh stock engine with aftermarket parts
I just want to make sure that it will work with OEM ECU
Old Jun 19, 2012 | 03:22 PM
buzz944's Avatar
I guess i'll do the aftermarket internal with stock 11.0 compression
Old Jun 22, 2012 | 01:07 PM
buzz944's Avatar
is it a good idea to bump the compression a little bit on the OEM ECU? or it'll lower timing and won't gain from the higher comp?
Old Jun 23, 2012 | 07:48 PM
HondaKyle's Avatar
Id say keep it stock comp. You wouldnt gain much any power with any of these mods with or without a tune.
89hybrid
Nov 18, 2014 03:02 PM
hmongyaj87
May 31, 2008 03:13 AM
Gojira D.O.T
Mar 8, 2006 03:57 AM
92eg6
Dec 29, 2005 08:43 PM
H23vtecEG
Sep 8, 2004 03:14 PM
