Need help with soft clutch pedal
Old Jun 16, 2012 | 02:02 PM
be4unvme's Avatar
Default Need help with soft clutch pedal
hey H-T, i urgently need help with my clutch. before anything else here is what happen to begin with. i was driving and stop at a red light when all of a sudden, i steepd on clutch pedal to put car in gear then i sunk right there on me. I was looking at the clutch lines where it ends at the slave cylinder so i bought a new slave cylinder and a stainless steel braided line and connect it. got it workin once i installed it and bleeded it. i turn on the car today and it didnt go into gear and pedal was really soft it had no pressure so i started pumping the pedal and gained pressure and it'll work for the moment but i have to pump the clutch for it to gain pressure. i was looking at the master but i cant seem to find any leaks looked inside the car for any leak by the clutch a nd its. dry, check the resv and its full..i noticed that when i push in the clutch pedal i hear ait squezzin out of the resv, is this normal? thanks for any help in advance
Old Jun 16, 2012 | 03:21 PM
be4unvme's Avatar
Default Re: Need help with clutch
anyone???? i think its the resv cap that is loose. i think im gonna have to change the whole thing out just hate buying those cheap part from autozone.
Old Jun 16, 2012 | 05:30 PM
Former User's Avatar
Default Re: Need help with soft clutch pedal
Sounds like you will need to replace the master cylinder and rebleed.
Old Jun 16, 2012 | 05:55 PM
be4unvme's Avatar
thanks for the help. I noticed that the slave cylinder is only held up by 1 bolt, i did.t think it would be much of a big deal so i didnt payed ny attention. i called up a buddy and he tild me to get that bolt in because the slave cylinder needs to be stiff. i just hope it works tomorrow. i hate replacing oem parts for those crappy parts.
Old Jan 1, 2014 | 06:22 PM
DC4_Lewi$'s Avatar
Did you ever find out the problem? Im having the same issue! I have to pump the pedal to gain any pressure to move!
98trooper
10
Aug 22, 2012 05:03 AM
Mashi2Choco
May 27, 2009 06:18 PM
2wheelhunter
Aug 30, 2006 07:56 PM
conceptEG
Aug 13, 2006 02:29 PM
92BlackSi
Oct 26, 2004 03:51 PM
