Clutch pedal goes all the way to the floor
"I HATE MONDAYS"
Get in the EK this morning to go to work, start the car, push the clutch to shift to...........WTF? clutch pedal goes all the way to the floor almost before there is any pressure, cannot go into any gear.
Was fine when I parked it last night, what gives??????????
Re: Clutch pedal goes all the way to the floor
So let us get this straight. You got in your car, pushed the clutch in (to disengage the safety switch), started the engine, let out the clutch, and then pressed the clutch again to put it in gear; that's when you noticed no pressure?
I think it's obvious you should check for leaks along your clutch line. It sounds like you have a leak somewhere in you clutch line that allowed a rapid decrease in pressure.
Also check to see if fluid is spewing out of your cylinder wall on your slave cylinder and if the pushrod is on the clutch fork insert. Mine slipped off for some reason oneday. Not fun.
Did you look inside your car where the push-rod connects to the pedal assembly? It sometimes leaks inside the car as well.
Retired Moderator
i was going ot say slave cylinder took a ****.. but if you already found the issue... good luck.
theres parts on the honda marketplace for cheap replacement.
http://www.hondamarketplace.com/
^^lol thanks fellers. Really was just bitching about my Monday but the title got changed. Guess I broke the rulez.
96 EX
11
05-15-2009 10:29 AM
Nations Sickest CRX
08-30-2005 03:53 PM
