Air Temp Reading 14 degrees
Old Oct 14, 2002 | 01:35 PM
sleepercivic's Avatar
Default Air Temp Reading 14 degrees
I was at the dyno and my air tempsensor is reading 14 degrees what could be the problem
TERRY
Old Oct 14, 2002 | 02:47 PM
Default Re: Air Temp Reading 14 degrees (sleepercivic)
anyone i need help fast
TERRY
Old Oct 14, 2002 | 03:15 PM
lightning's Avatar
Bad temp sensor, bad ground, corroded connections...Maybe it was that cold and you didn't know it
Old Oct 14, 2002 | 06:02 PM
Default Re: Air Temp Reading 14 degrees (lightning)
no it was on the dyno we went through the connection and the wires were all connected, what ground would make it go bad, also i have never heard of a sensor goin bad, anyone else have any ideas
TERRY
Old Oct 14, 2002 | 06:28 PM
any one i need this fixed in 2 days
TERRY
Old Oct 14, 2002 | 10:50 PM
ttt
Old Oct 15, 2002 | 03:13 AM
Chiovnidca's Avatar
TERRY
They can and do go bad. Just not very often.
Old Oct 15, 2002 | 05:26 AM
Default Re: Air Temp Reading 14 degrees (Chiovnidca)
would this then most likely be it?
TERRY
Old Oct 15, 2002 | 08:03 AM
EE_Chris's Avatar
If you have access to a mutli-meter you could do a simple test. The IAT & ECT share the same resistance/temp characteristics. On a cold motor [in the morning time works well] unplug the IAT & ECT sensor connectors. Then measure the resistance of both sensors.....they should be nearly the same.
But as far as IAT [and ECT for that matter] resistances for varying temps, use these values:
Temp: Ohm
32: 5000
68: 3000
104: 1000
If your sensor checks OK, look to your wiring.
Old Oct 16, 2002 | 08:16 AM
Default Re: Air Temp Reading 14 degrees (EE_Chris)
Thanks alot im gonna be tuning again this friday and hopefully a new sensor will dothe trick if not is there anything else it could be
TERRY
sciencemagic
May 5, 2014 06:51 AM
sciencemagic
Honda Civic (2006 - 2015)
Apr 23, 2014 08:08 AM
kendezzy
Nov 23, 2010 09:15 PM
EJ8 GSR-T
Honda S2000
Dec 25, 2007 05:42 AM
importnoodles
May 21, 2005 09:37 PM
