Motor breaking up after 7000 rpm
Old Jun 15, 2012 | 04:15 AM
crappyhatch's Avatar
Default Motor breaking up after 7000 rpm
So I'm trying to tune my car and we can't get the motor to go over 7000rpm. I'm running a s300 with cpr. Motor is fully built(block and head) and should easily rev to 11,000rpm. All I can seem to think is the plugs im running are not right for my setup. Im running ngk v-power 4091. Our power goals are 675-700whp, anyone running this type of set up and ever run into this issue? Thanks
Old Jun 15, 2012 | 03:35 PM
dantamparacer's Avatar
Default Re: Motor breaking up after 7000 rpm
What is the actual part number on the plug? I am too lazy to look it up. What other ignition upgrades have you made? I had a similar issue a few years ago the runner and I thought that it was ignition problem and replaced everything and it ended up being a bad map sensor
Old Jun 16, 2012 | 06:13 AM
The plugs I was running were ngk 4091's. We found the map sensor to be bad and also switched to a ngk iridium 6988. Problem solved and just for curiousity sake we made 641whp/388tq on 32psi! Thanks for the help!
redrider123463
Jun 17, 2015 05:45 PM
one slooow dc4
Nov 15, 2009 06:39 PM
pumafeet10
28
Mar 15, 2008 10:46 AM
AzN_Flava
Jan 7, 2007 01:37 PM
88hondahatch
Aug 30, 2005 12:07 AM
